Assigning arrays with values from from BS2.PULSIN
Hi All,
I've been struggling this weekend on using the propeller's BS2 PULSIN function to count radio control receiver's pulses. If I assign each of my 6 inputs to unique variable (like Rx3 := BS2.PULSIN(3,1), I have no problems. Also, If I manually assign values to an array (like rx := 1000) and display them I am good. But when I try to assign the array in a loop I get all zeros when I read out the array. My code snip:
In this example the input pins are the same as the counter value. The array is available to all cogs.
Any help with array assignment is appreciated!
Paul
VAR
long rx[noparse][[/noparse]6] ' is this needed?
PUB AssignArray | i
repeat
repeat i from 1 to 6
rx[i] := BS2.PULSIN(i,1) 'to assign rx(i)
PUB ArrayShow | i
' repeat i from 1 to NumSrv
' text.dec(rx[i]) ' commented area doesnt work. trying to output value of rxi array in a column
' text.str(string(13))
' show receiver input from array (Works)
text.str(string($A,5,$B,4)) 'set position
text.dec(rx) 'display Rx Channel 1 pulse count
text.str(string($A,5,$B,5)) 'set position
text.dec(rx) 'display Rx Chan 2
text.str(string($A,5,$B,6)) 'set position
text.dec(Rx) 'display Rx Chan 3
text.str(string($A,5,$B,7)) 'set position
text.dec(Rx) 'display Rx Chan 4
text.str(string($A,5,$B,8)) 'set position
text.dec(Rx) 'display Rx Chan 5
text.str(string($A,5,$B,9)) 'set position
text.dec(Rx[noparse][[/noparse]6]) 'display Rx Chan 6
[/i][/i]
Paul
Assuming you're trying to write
PUB AssignArray | i repeat repeat i from 1 to 6 rx[noparse][[/noparse] i] := BS2.PULSIN(i,1) 'to assign rx(i) PUB ArrayShow | i ' repeat i from 1 to NumSrv ' text.dec(rx[noparse][[/noparse] i]) ' commented area doesnt work. trying to output value of rxi array in a column ' text.str(string(13))The biggest problem I see is that subscripts run from 0 to one less than the array size. You'll overwrite the next long after rx[noparse][[/noparse] 5].
I assume you're running AssignArray in a separate cog. What follows rx? Maybe AssignArray is overwriting it's stack area.
I still haven't figured out how you are able to read and reply to every post here. Wow! Thanks for the formatting tip - I didn't catch that but wondered about the italics... You are correct in what was meant.
Yes, I have ArrayAssign on its own cog, ArrayShow runs on the first cog, and I've tries on its own with the same result.
I've started at 0 and thought about the stack size, so I intentionally created an array larger than I needed - no luck :-(
I'm a new-again programmer, so I think I must have the logic wrong. I'l lkeep plugging away.
Paul
It's also helpful to include a schematic or at least a description of what's connected to what.
