Understanding Gait Tables
Hi.
I have been looking at a couple of projects wich is using the Parallax propeller together with the Hexcrawler, and everything seems very fine. But im having trouble understanding the Gait tables they are using. An example of a Gait table is this:
How should i read these tables?
' Adjustable vertical servo positions
RaiseRight = 300 ' Raised and lowered
LowerRight = 1200 ' Vertical servo values
RaiseLeft = 1200
LowerLeft = 300
DAT
' Gait Tables
Home long $01, RaiseRight, $05, RaiseRight, $09, RaiseLeft
long $03, RaiseRight, $07, RaiseLeft, $0B, RaiseLeft
long $01, LowerRight, $05, LowerRight, $09, LowerLeft
long $02, Center, $06, Center, $0A, Center
long $03, LowerRight, $07, LowerLeft, $0B, LowerLeft
long $00, Center, $04, Center, $08, Center
long $FF
Fwd long $01, RaiseRight, $05, RaiseRight, $09, RaiseLeft
long $02, Leg2Back, $06, Leg4Back, $0A, Leg6Back
long $00, Leg1Forward, $04, Leg3Forward, $08, Leg5Forward
long $00, Leg1Back, $04, Leg3Back, $08, Leg5Back
long $02, Leg2Forward, $06, Leg4Forward, $0A, Leg6Forward
long $FF
http://forums.parallax.com/member.php?u=43060
It's hard to know what to explain since you don't indicate what you do not understand (of course, sometimes we don't know what we don't know and that itself is another problem), and do not provide the context (the rest of the code) which shows how those "gait" variables/values are used by the particular·program.
Can you provide a pointer to the entire source code?
Have you read through the entire source code to see how these tables are referenced by the code that actually uses these data (tables)?
Then, any more specific questions?
PAR
