Serial Connection between Prop and SX
I have sucessful comms between the Prop and SX, but my question is this.. I have the prop and the SX connected with two wires an RX and a TX line.. the RX line on the prop has a resistor to lower the current. When I remove power from the SX the power light still seems to glow faintly like there is power coming from some where, when I disconnect the serial connection the power light goes out completely. Is this normal? or is there some way to prevent this.
I hope that made sense.
Thanks for any insight,
Eric
Eric
Post Edited (originator) : 3/15/2007 12:56:02 PM GMT
The SX is getting power from the propeller though the serial line. The SX has protection diodes on the inputs to limit the voltage, so when the input is higher than Vdd the diode conducts the input pin TO Vdd. So your circuit gets powered by 3.3V - 0.7(for the diode voltage drop).
Bean.
"A problem well defined is a problem half solved"
"Just because you're approved, doesn't mean you can afford it."
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Coming soon! Propeller based OSD module www.hittconsulting.com
Paul Baker
Paul Baker
Post Edited (originator) : 3/15/2007 7:47:19 PM GMT
