How do I make my computer Vista/XP dual-boot ?
Bean
Okay, I know this isn't really Parallax related, but I need expert help, (in more ways than one[noparse];)[/noparse]
I recently purchased a compaq/HP machine with Vista Premium on it.
It is working okay, but I would like to now make the computer be able to boot either XP or Vista.
Has anyone done this ?
Can I do it without reinstalling Vista ? All I have is the "restore" CDs.
Do I need to buy "Partition Magic" or can I do it without it ?
Bean.
"A problem well defined is a problem half solved"
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Coming soon! Propeller based OSD module www.hittconsulting.com
Bean.
Post Edit: Or you could just get another harddrive and install XP on it.· Then swap them out at your plesure.
NerdMaster
For
Life
Post Edited (crgwbr) : 3/13/2007 3:22:55 PM GMT
sorry, but to put both OSes on the same drive you need to start with a fresh drive and install XP first. No other way around it.
I've set many up and they all have to be this way.
Cheers,
- Bob -
How to fix Vista not starting after you install a second (earlier) version of Windows in a dual-boot configuration
- Rick
Post Edited (RDL2004) : 3/14/2007 3:54:10 AM GMT
Suggest have a look at MS·· http://www.microsoft.com/windows/products/winfamily/virtualpc/default.mspx
bongo
I think I go with a 2nd hard drive. I hate to mess up my Vista setup now.
Bean.
"Just because you're approved, doesn't mean you can afford it."
Running XP in a VM under a Vista host has been getting pretty good reviews. And MS VM 2007 is free...
Truly Understand the Fundamentals and the Path will be so much easier...
If VMWare player works fine under Vista, I recommend it over the MS VM. Performance is quite a bit higher.
As mentioned above, check out VirtualPC. It is free and you can run a whole host of operating systems. This really is a great piece of software.·
I've run into so many dual boot issues that I've finally settled on a procedure that I'm confident of:
1. Each OS gets ity's own hard drive
2. The ONLY hard drive connected to the system during OS installation is the one that you are installing to. Unplug the power and data cables for other drives. This is the only reliable way to prevent the OS installation from modifying anything on your drives - data or boot sector.
3. Once the OS is installed, reconnnect your drives.
4. On boot up, pressing the escape (Esc) key will usually give you a boot selection menu - just choose which drive to boot from. You may need to mess around with the controller configuration, or add an additional IDE controller card.
This works well if you need the OS to run on the bare metal. Otherwise, VirtualPC or VMWare are the way to go. You will lose some performance on some apps, so a very fast processor(s), drives, and 2GB+ of memory are recommended.
