Basic Programming newbie
·Just getting started and I need some help with the LOOP statement. How doyou break out of the loop once your input is met?
ie:
DO
IF· (IN3=1) then ???? how do I go tp my next statment once this is me?
LOOP
Next statement Here
ie:
DO
LOOP
Next statement Here
Loop until (IN3 =1)
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Chris Savage
Parallax Tech Support
Thank you very much.
Pete
Note that Chris Savage is using the work "Exit" as a lable·for another part of the program as in...
Main:
DO
· IF IN3 = 1 THEN Go_to_this_part
LOOP
Go_to_this_part:
' do something different here
I believe EXIT was added with version 2.5 as a means to exit loops cleanly, so it's actually an instruction and not a label.
-Martin
Chris Savage
I am an "old-head" code cutter. The last time I used a language that forced one to utilize a "premature exit" was the 8008 instruction set, one bit at a time! However, I admit that Parallax's implementation of it makes a lot of sense.
Ha! I am LOOKING at the machine I used it on! Wonder what it is worth today? (Nothing, probably.)
--Bill
You are what you write.
