need of a pbasic programmer
Hi there to all. i am in need of a programmer who can write a program on pbasic. I am trying to take datas from ping ultrasonic sensor and by using these values controlling a servo motor. The parts i have are
My job consists of two parts. The first part will be done without servo. The sensor will measure the distance only and display it on computer. Second part is build on this part. In the second part i will use the distances and send commands to servo. This will happen like this. If the distance measured is between 0 and 30 servo will rotate left a little bit and when it reaches·30 it will stop. But when the distance gets more than 30 it will turn a little bit right. This action will be contunious, i mean the servo will always react to the distances. There will·be no end until i close the system. The system will turn left and right. If somebody can help me on this i will be very happy. İ am able pay through paypal. Hope to hear from yuo soon. my mail address is gidiyorss@gmail.com
- Basic Stamp 2 module microcontroller
- parallax servo
- ping ultrasonic range finder
- board of education - Usb Board
- Stephen
You have been given plenty of information to get started on your own. Most of the people here with the knowledge and experience to do what you want charge a lot of money for their time and generally would do their work on the basis of a contract that sets out clearly the terms of the project. Given that you are an unknown, they likely would like most of their money in advance. I suggest you stop posting requests (since you've already asked three times and not gotten any takers) and start reading the tutorials and working through the examples. You'll find that you'll learn a lot and you should be able to do the project yourself.
