Rf network of 6-10 bs2 boe-bots
Hi group,
I'm thinking of using the BS2 boe-bots to implement a sensor network project that I'm working on. My question is if there is enough resources on BS2 board to simultaenously control movement of the boe-bot, monitor the sensors to detect objects, monitor current position using GPS, broadcast coordinates to a PC (using RF), and recieve (using RF) coordinates from a PC. From the little research I've done, it seems like the Javelin is better suited for these kinds of tasks.
Does anyone with RF experience know if I cau use the parallax rf modules to network multiple boebots? Any inputs you could provide would be greatly appreciated.
Bluetooth Boe-Bot Robot·for Microsoft Robotics Studio
Other options for doing it all on the fly (no servo controller required) include switching to either the Javelin Stamp or Propeller Microcontroller. Especially if you want to have all the robots communicate and function autonomously without a PC base station, the Propeller microcontroller is probably your safest bet for a processor.
Propeller·chip on Boe-Bot forum thread with picture and some code that follows an object with dual PID distance/servo control loops.
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 3/8/2007 9:37:51 PM GMT
It seems like the Javelin is more suited for multi-tasking assignments, plus the Java interface looks a lot neater and considerably more powerful and intuitive than the procedural PBASIC!
So keep those boe-bot kits and use them with the proto-board instead.
my 2 cents,
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Do you have time to expound a bit on wifi's (G) inadequacy in this situation? And, would you say something about 802.11G as the carrier between a PC and a single device, but one with a "lot" of simple I/O? (Joint positions, proximity detection, and collision sensors, mainly.) I know this is vague, but so am I. Your words are valuable to me.
Thanks!
--Bill
You are what you write.
I don't think WiFi is in any way inadequate. It's kind of complicated for the task and pretty much any implementation will take more power than you're probably spending on everything else except motors even if it is only 1-2W. If you were using embedded Linux or a similar system on an appropriate processor, I'd think WiFi would be a preferred wireless link, but you're not. Bluetooth is a nice single master, multiple slave system with good range, reliability, and addressability and would fit in with your network. xBee is, to my mind, better because it has an addressable packet-based mode, it's low power, reliable, and less complicated than WiFi. If needed, the BOE-BOTs can communicate with each other as well as with the "base station". To the "base station", the I/O looks like a serial port which is usually easier to manage in most high level languages than multiple network connections.
I'd second Martin's suggestion about using the Propeller. The Javelin is still a single processor even though it can do certain I/O "in the background" using interrupt routines. The Propeller really is a multiprocessor. You will use one processor for talking to the network, one for bit-level serial I/O, another for servo control, maybe do most of the sensors with one processor. That still leaves a couple.
--Bill
It's a nice illustration of being able to monitor and control 3 bots, switch them to autonomous mode, or control all as a group using broadcast address.· I posted the code, macro and a short discussions at:
http://www.selmaware.com/stampplot/xbee/xbee_bots.htm
-Martin
Post Edited (Martin Hebel) : 3/9/2007 8:04:06 PM GMT
I'll definetely keep you guys posted with my testing, and the code as it progresses along.
Also, isn't java more in line with what industry uses (C++ for embedded software industry) ?
There's no problem in using the Javelin. Do keep in mind that there's no dynamic memory allocation, particularly an issue with string use.
As you start prototyping and putting this together, do post your progress and problems that you run into. There's a tremendous amount of experience among the various members of this forum. If you do go with the Javelin, use the Javelin forum and the Sandbox since this particular forum is specific to the Stamp processors.
In terms of industry use of Java, there's very little use in microcontrollers and Java requires a lot of processor "horsepower" to support. About the smallest platform I've seen with wide usage of Java is the Palm and PocketPC. I imagine you'd find some support with the ARM type larger embedded processors. It's rare to see Java on something like the SX processor (the Javelin).
Post Edited (Mike Green) : 3/9/2007 9:55:42 PM GMT
