Strings help — Parallax Forums
Strings help
El PaisaEl Paisa Posts: 375
edited 2007-03-08 04:48 in Propeller 1
I hope anyone can help and thanks in advance.
If I have:
DAT
·· msg0···· byte···· "0.bmp",0
·· msg1···· byte···· "1.bmp",0
·· msg16·· byte···· "multi.bmp",0
·· msg17·· byte···· "div.bmp",0
and I need to send to a serial device each dat definition one at the time, which is the proper way?
    edited 2007-03-07 18:42
    You could have a table:
    table   word  @msg0, @msg1, ... @msg8
              word  @msg9, @msg10, ... @msg17
    Then do:
    repeat i from 0 to 17
      ser.str(@@table[noparse][[/noparse] i]))
    The "@" operator at compile time provides the object relative offset of each address. The "@@" operator turns these into absolute addresses.
  • El PaisaEl Paisa Posts: 375
    edited 2007-03-07 18:47
    Thanks Mike, I did not expect a so fast response.
    edited 2007-03-07 18:53
    I have also used LOOKUP to index an array of pointers. These can be dissimilar and randomly accessed if nessesary.
    Paul Baker
  • Russ FergusonRuss Ferguson Posts: 206
    edited 2007-03-07 21:16
    Paul:
    Please give a code example.
    edited 2007-03-07 21:38
    Sure, here is a section of my logic analyser program where I am doing nibble replacement using a hex value (in_value) entered by a·keyboard and converted to a numeric.
          vptr := lookupz(field: @wmask, @wval, @wtime)       'retrieve pointer to variable
          if(position//2 == 0)                                'change high nibble
            BYTE[noparse][[/noparse]vptr][noparse][[/noparse]3-position/2] &= NMSK                  'clear high nibble
            BYTE[noparse][[/noparse]vptr][noparse][[/noparse]3-position/2] |= in_value << 4         'set high nibble value
          else                                                'change high nibble
            BYTE[noparse][[/noparse]vptr][noparse][[/noparse]3-position/2] &= !NMSK                 'clear low nibble
            BYTE[noparse][[/noparse]vptr][noparse][[/noparse]3-position/2] |= in_value              'set low nibble value
    So this code·arranges a set of variables as a psuedo array regardless of thier names
    Paul Baker
    edited 2007-03-08 03:03
    Hi Paul,
    the problem i found is if i use:
    · repeat i from 1 to 16
    ····· char:=lookup(i:msg1,msg2,msg3,msg4,msg5,msg6,msg7,msg8,msg9,msg10,msg11,msg12,msg13,msg14,msg15,msg16)
    ····· term.str(@char)
    ····· term.out(13)
    DAT
    · msg1······· byte····· "0.ezp",0
    · msg2······· byte····· "1.zp",0
    · msg3······· byte····· "2.ezp",0
    · msg4······· byte····· "3.zp",0
    · msg5······· byte····· "4.ezp",0
    · msg6······· byte····· "5.zp",0
    · msg7······· byte····· "6.ezp",0
    · msg8······· byte····· "7.zp",0
    · msg9······· byte····· "8.ezp",0
    · msg10······· byte····· "9.ezp",0
    · msg11······· byte····· "plus.ezp",0
    · msg12······· byte····· "minus.ezp",0
    · msg13······· byte····· "multi.ezp",0
    · msg14······· byte····· "div.zp",0
    · msg15······· byte····· "spin.bmp",0
    · msg16······· byte····· "propeller.bmp",0
    It only prints the first character of the string.
    I need to print the whole string ie, "propeller.ezp"
  • Martin HebelMartin Hebel Posts: 1,239
    edited 2007-03-08 03:37
    Here's just a guess on my part, but @char passes the address of char variable. Using the lookup table, char actually holds the address of the string you want, so try using:
    term.str(char)
    Though I'm not sure why @char even gives the 1st correct character.
    -Martin
    StampPlot - GUI and Plotting, and XBee Wireless Adapters
    Southern Illinois University Carbondale, Electronic Systems Technologies
    edited 2007-03-08 04:03
    Rethinking this, and looking back on what Mike Green had posted, what you probably want is this:
    ···· char:=lookup(i:@msg1,@msg2,@msg3,@msg4,@msg5,@msg6,@msg7,@msg8,@msg9,@msg10,@msg11,@msg12,@msg13,@msg14,@msg15,@msg16)
    So that char DOES hold the address of the message, and that address is sent to term.str.
    Correct Martin, though Im not sure if term.str(@char) or term.str(char) is needed since char contains an adress. The reason for the result being the first character only being printed is that the value of the string was being assigned to char which is the first character of the string.
    Paul Baker
