Monitoring battery power level
Hello All:
Is there a simpler way to monitor battery power level on the BS2?
Or is the POT command the simplest way to monitor a voltage level tied back & scaled (of course) to an input?
M.D.
M.D.
The POT command is a BS1 command…You’re asking about a BS2, so I would recommend RCTIME. You can find an example at Dr. Tracy Allen’s website. Take care.
http://www.emesystems.com/BS2rct.htm#B_voltage
Chris Savage
Parallax Tech Support
Thanks alot - It is the same general idea...
However, this is more elegant.
Mike D.
M.D.
