Proto Board
Hi
I have a few questions.
1. What would be the best way to mount a bread board and female pin header onto the proto board (e.g location)
like on the BOE?
2. How do you add a video out (TV) to the proto board.
3. If i use
on the BS2 what would i use on the propeller proto board.
Thank you
like on the BOE?
3. If i use
FOR Pulses = 0 TO 199 'for 200 pulses PULSOUT 12,625 'go forward at half speed PULSOUT 13,750 'go straight PAUSE 20 NEXT
Thank you
You could use the BS2Functions object and something like
OBJ BS2 : "BS2Functions" PUB Pulses repeat until pulseCount = 199 'for 200 pulses BS2.PULSOUT( 12, 625 ) 'go forward at half speed BS2.PULSOUT( 13, 750 ) 'go straight BS2.PAUSE( 20 )NOTE: Just done that off the top of my head, so·check the syntax -- and the timing numbers are probably not right!
HTH.
Cheers,
Simon
BTW: I type as I'm thinking, so please don't take any offense at my writing style
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
I've got no experience with BS or its compatibility functions, but I can say that this spin code is wrong.
EDIT: repeat until pulseCount == 199 would literally repeat until pulseCount equals 199. However, pulsecount is never initialized to zero here. also, it is never incremented. the "from ... to" structure increments it automatically, until won't. Also, == is used for comparison, a single = is never used for anything.
Following should work: (at least, compile and loop for 200 times)
OBJ BS2 : "BS2Functions" PUB Pulses | pulseCount repeat pulseCount from 0 to 199 'for 200 pulses BS2.PULSOUT( 12, 625 ) 'go forward at half speed BS2.PULSOUT( 13, 750 ) 'go straight BS2.PAUSE( 20 )Post Edited (Jasper_M) : 3/5/2007 1:55:40 PM GMT
Well, yes, that's another way to do it; especially as I missed the 'pulseCount' incrementer! Here's my way done better
OBJ BS2 : "BS2_Functions" PUB Pulses pulseCount := 0 repeat until pulseCount == 199 'for 200 pulses BS2.PULSOUT( 12, 625 ) 'go forward at half speed BS2.PULSOUT( 13, 750 ) 'go straight BS2.PAUSE( 20 ) pulseCount++That said, I think I like your way better, as it more closely resembles 'computer guy's' original code
Cheers,
Simon
Post Edited (simonl) : 3/5/2007 2:19:14 PM GMT
OBJ BS2 : "BS2Functions" PUB Pulses repeat 200 'for 200 pulses BS2.PULSOUT( 12, 625 ) 'go forward at half speed BS2.PULSOUT( 13, 750 ) 'go straight BS2.PAUSE( 20 )-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
For the question about video connector, I'd suggest taking a look at the schematic for demoboard (downloadable from Parallax site). It's just like.. 3 or four resistors and the connector. If you're asking about the mechanical connection, ie. how to get the connector soldered to the protoboard, that's another thing. Most of the RCA connectors I've seen have very big pins that don't fit the standard veroboard holes. So you probably have to connect the RCA connectors with wire and then superglue/screw the connector to chassis/whatever you are building...
Martin: Why can I never remember KISS ?!
Cheers,
Simon
Also, I never explained how the yellow wire is connected to the resistors. I stripped 1/2" of insulation from the wire. inserted it into the hole next to the leftmost resistor. Bent it over and soldered it to the tips of the resisters that protrude from the bottom of the board. Or you could just create one huge solder bridge.
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
Post Edited (parts-man73) : 3/5/2007 5:19:00 PM GMT
Also the price on the protoboard is given in some places as $24.95 and others as $19.95.
Paul Baker
Paul Baker
Paul Baker
everyone.
parts-man did you just glue it on the board or did you poke the big mounting pins through the large holes on the outside of the proto board.
and if anyone could still answer my first question that would be great.
Once again
Thank you
Place it where you want, flip·it·and the board·around, use a razor or xacto to score along the edge of the board and remove the adhesive backing for that part which is over the protoboard.
If you are using the servos you can solder 1x4 SIP socket into the contol signal holes·for easier breadboarding.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 3/5/2007 9:17:39 PM GMT
"101 proto-board projects"
Not sure about the bread board hanging off the side but a piece of perspex on the proto board hanging
over with the bread board on top may look beter.
I am asuming you are saying you could see a need of a book titled "101 proto-board projects"
I would personaly like a book like this.
Thank you
Post Edited (computer guy) : 3/7/2007 6:37:34 AM GMT
Please note the quote was from this topic:
http://forums.parallax.com/showthread.php?p=634772
Thanks.
Post Edited (computer guy) : 3/6/2007 7:10:36 AM GMT
I trimmed the big mounting pins with a dremel until they were small enough diameter to fit through the regular plated holes. Just be careful not to cut the pins right off.
I ran into a problem, the Stereo headphone jack that I bought at the local electronics store wasn't as I had hoped. The pins don't fit into a 0.1" grid as nicely as the RCA jack did. Once I find one that does, I'll post pictures!
Brian Meade
don't you hate it when parts don't fit. Why can't there be a standard that all electronics must fit a 0.1" grid.
Thank you
i have tried servo32, servo4 and BS2_Functions.
none of which seam to fix the problem.
I have tried it with and without a 470 ohm resistor on the signal pin.
470 ohm
Prop---/\/\/\---servo
+5v
|Servo|
-VSS
Thank you
Post Edited (computer guy) : 3/11/2007 8:32:59 AM GMT
Paul Baker
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 'Note Clock Speed for your setup!! High = 1 'A CONstant used to set an output port to about 3 volts Low = 0 'A CONstant used to set an output port to about 0 volts Out = %1 'A CONstant used to set a port's direction to Out VAR Byte Pin 'Declares Pin to be a global VARiable of a type Byte ' OBJ BS2 : "BS2_Functions" PUB Start BlinkingLED 'Calls the PRIvate procedure BlinkingLED BS2.PULSOUT( 8, 625 ) 'go forward at half speed PRI BlinkingLED 'A PRIvate procedure named BlinkingLED Pin := 4 'Assigns 16 to the variable Pin DirA[noparse][[/noparse]Pin] := Out 'Makes port A16 an output port Repeat 5 'Repeats the code indented under it 5 times 'TURN THE LED ON AND OFF ' -- The LED, at port A16, is on for 1/2 second and off for 1/2 second. ' -- The System Counter increments by one for every System Clock pulse. Thus, if the ' System Clock is running at 80MHz, the System Counter will increment 80 million times ' in one second; and every counter increment will take 12.5ns (1/80MHz). ' Each WaitCnt statement below is set to cause a 1/2 second wait: ' 40_000_000 counter increments * 12.5ns = 500ms (1/2 second) ' OutA[noparse][[/noparse]Pin] := High 'LED ON WaitCnt(40_000_000 + Cnt) 'ONE-HALF SECOND WAIT OutA[noparse][[/noparse]Pin] := Low 'LED OFF WaitCnt(40_000_000 + Cnt) 'ONE-HALF SECOND WAIT ' 'INDENTION IS IMPORTANT IN SPIN: There are no ENDIFs, END REPEATs, END SUB, etc.Thank you
Paul Baker
I think the power supply has fixed the problem i just need to fix the program to loop.
can the propeller execute more than one commend at a time if so how many (in one cog).
Thank you
Paul Baker
