Processor Speed - Pulsout
Here's an easy one:
Does the processor speed·affect the PULSOUT ?
If the BS2 at 20MHz is running a stepper driver with:
··· FOR counter = 1 TO 1200
··· PULSOUT 14,1
··· Pause 0··········
would the motot run at a higher RPM if the BS2sx at 50MHz·ran the same code ?
I wouldnt think so, but..............? I also noticed that if I PULSOUT without the counter it runs substantially faster, I guess because it doesnt have to count the pulses. So if I did this with both stamps, would one run faster than the other ?
····· DO
··········· PULSOUT 14
······LOOP
··· PULSOUT 14,1
····· DO
······LOOP
Duration dropping from 2us to 0.8us would be substantial if the drivers were capable.
Please bear with me, I'm learning.
Regards
Appreciative
