Emic Amplification / Suggestions for (Simple) Audio Amp Chip
I've got an Emic module with the onboard audio amp. The volume (with a speaker enclosure) is pretty good, but I want more volume.
I've got some L386 Audio Amps lying around, but according to the datasheets, these are actually *less* powerful than the 300mw onboard amp of the Emic.
So... does anyone have any suggestions for an audio amp chip that would be as easy to wire up as the LM386? Also, in looking over the spec for load/resistance/etc for use with the Aout of the Emic, I realize I'm a bit lost.... would I still need to condition the Aout signal for beyond a "typical application" for an audio amp?
Basically, I'm not sure what this means:
Post Edited (Zoot) : 3/2/2007 3:09:55 AM GMT
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔Somebody said...
Audio output buffer pin provides a single-ended analog output of the
synthesized speech for external amplification. Drives a minimum load of
5k Ω up to a maximum of 1Vp-p. The AC signal is superimposed on
approximately 1.2VDC bias and must be capacitively coupled to the
load.
Chris Savage
Parallax Tech Support
I just looked over datasheet for LM386-1 and realized that the mw output I was presuming is based on 5v-6v supply -- it looks like if I use 9v supply the LM386 will give me ~700mw out -- which would be a nice volume.
Either way, it looks like the input resistance for these amps is high enough that I can drive them with the Aout pin of the Emic -- but what value cap would I use for the "capacitive couping" -- I presume this means a series cap between the Aout pin and the amp circuit.
Of course, I'll have to wait for my Emic to be repaired (or replaced by me or Parallax) -- thanks for your help on that Chris.
I built the LM386 Audio Amp circuit following Parallax's AP-8 amp circuit (see attachment below). I'm supplying the circuit with 9v, and I ran FREQOUT signals through it and it sounds GREAT. And LOUD.
Now, my real goal is to feed my FREQOUT into the AIN pin of my Emic, and then the AOUT of the Emic into my LM386 circuit. The onboard amp of the Emic isn't quite loud enough for me. I've already built the conditioning circuit to convert the FREQOUT signals into a form acceptable for the AIN pin, and this works great with the onboard amp (see add'l schematic below).
That said, I am confused about how to correctly modify the input portion of the LM386 circuit to accept the AOUT signal. The Emic manual states:
Clearly the LM386 schematic has more than a 5k load, and is capacitively coupled (that means a series cap, right?). But it seems I can cut out the bypass caps and resistors since those are used for converting the FREQOUT to sine waves? But which ones? Do I just need a single series resistor and series cap before the volume control to get the right load and capacitance? If so, what values? Or am I totally off?
Thanks in advance.
Post Edited (Zoot) : 3/2/2007 2:46:55 AM GMT
My suggestion would be to to take Aout from the EMIC directly into the left side of the 10uF capactior on the '386 amplifier and dispense with the part of the ampllfier that comes before that. Use the circuit that goes to Ain on the EMIC as is.
Tracy Allen
www.emesystems.com
The 10k ohm audio pot I got from Radioshack was causing LOT of line noise, so I tried substituting a 5k pot that I happened to have.. the 5k one works much better, but I have a couple of questions:
* What's the implication of using a 5k pot vs. a 10k pot?
* I've noticed that there's a slight high-pitched buzz that I can minimize by moving around wires or by touching the 220 uF capacitor... what sorts of things should I be looking at to eliminate the buzz in a more rigorous manner?
Thanks!
Using a 10k would cut the adjustable range in half, plus you'll be sending more current through.
I had some hum -- probably due to a generally noisy robotic platform -- I put a few small value caps (.01 and .02) in parallel with the 10uf cap in front of the LM386's volume pot. Additionally I put noise suppression .1 caps on the power rails to the amp circuit which helped greatly.
Lastly, a breadboard version of the amp seemed much more susceptible to noise than the prototype board with the same circuit soldered.
But take these possible solutions with a grain of salt -- I'm certainly no audio amp expert
I cut and pasted the two schematics together as I wired up the circuit. I will add that I ended up including decouping cap on the power rails to the amplifier which cut down on speaker "hum", but my 'bot has always been a pretty noisy platform.
Adjustment & Software: remember that Ain is UNAFFECTED by the serial volume commands that change the volume of Emic text-to-speech generation. All your FREQOUTs to Ain will be the same volume. So you want to "mix" the volumes with the pots so that your FREQOUTs aren't way louder then the loudest text-to-speech (vol = 6). Or however you like it.
I set the master amp volume so that the loudest speech sounded nice, then I adjusted the Ain volume so that FREQOUTs were a touch softer than the loudest speech. This gives me so leeway to make speech louder or softer compared to FREQOUTs.
I debated putting a digital pot on the Ain conditioner circuit which would let me change volume on the fly for FREQOUTs, but that's for another time. I also considered two amp channels -- one for Emic TTS and one for FREQOUTs -- which would allow TTS and sound simulatenously, and from different locations on the 'bot body, but I think I'll do that for a 'bot with an even louder amp
Post Edited (Zoot) : 9/11/2007 4:48:05 PM GMT
Thanks for the quick reply. The latest diagram clears up all my questions. That is what I thought you all were talking about, but I just wanted to make sure. I did not want to let any "blue smoke" out of my unit. I am going to try the circuit today.
······ Joe Fishback
-Robots are my friends-
· In your latest posted schematic, it looks to me like the upper ground connection at the speaker·is a mistake...·that connection shorts the audio output directly to·ground.· If you look at the Parallax audio circuit, the upper ground connection is supplied for the external speaker option, as set by the jumper and maybe it was carried over to the new schematic unintentionally.
Tim
Post Edited (Tim-M) : 9/11/2007 2:16:21 PM GMT
Corrected.
