Servo Output
I have a motor controller that requires 2 servo inputs in order to control 2 motors.
I need to know how to get the BS2 to output this:
Please note 'input' is into the motor controller. From the BS2
Thank you
Computer Guy said...
Input Signal:
Input method..........40-70Hz PPM 1.5mS Mark Center [noparse][[/noparse]RC standard]
Input Voltage..........2.2v - 18v Max
Input resistance..........50kohm
Input current..........Fixed at 5mA/Channel
Thank you
That magic seeming "40 to 70 Hz, 1.5 mSec Mark Center", really means:
40 Hz == every 25 milliseconds
70 Hz == every 14 milliseconds
1.5 mSec Mark Center == "1 mSec is full left, 2 mSec is full right, 1.5 mSec is stop"
So, you must send this thing, using PULSOUT, a 1 mSec to 2 mSec signal, repeating that signal every 20 mSec. Just like a "normal" modified servo control signal.
Which looks like:
MAIN:
PULSOUT LeftSig, 500 ' On a BS2, there's 2 uSec per 'tick', so 500 'ticks' is 1 mSec
PULSOUT RightSig, 1000 ' 1000 'ticks' is 2 mSec. If you have the motors back-to-back, one spins left while the other spins right to go forward
PAUSE 20
GOTO MAIN
My motors are left and right motors so they are different to each other.
so i would use
MAIN:
PULSOUT RightSig, 500
PAUSE 20
GOTO MAIN
to go full speed forward/backward and
MAIN:
PULSOUT LeftSig, 1000
PAUSE 20
GOTO MAIN
to go full speed in the opposite direction.
Once again thank you
