Will the Hydra ever adapt to a USB game controller?
LoopyByteloose
Though I am quite happy without the USB controller at this time, the NES controllers are not easily available in Taiwan.· Obviously with NES, you have the opportunity to built a DIY controller.
But once again I suspect it is a case of Taiwan eliminating unwanted inventories to countries that buy their surpluses.·· In some cases, I suspect other countries never had NES and never will.
So, I am wondering if the Hydra will ever develop [noparse][[/noparse]possibly a card] USB interface to support more ubiquitous game input devices?· Similarly, I envision that many users would like the Propeller to support such a device rather than have to build joystick inputs.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
As for USB, I think it would be difficult for the HYDRA seeing as how everything is already soldered onto the board. You could definitely create your own board utilizing USB, but then it wouldn't be the HYDRA.
The component also is 3.3volts and uses about 25ma.
Having said that. It seems we already have the UART object in SPIN. So it is entirely a matter of the creation of firmware and an ever so tiny board to plug into the Hydra's game cartrige port. EEPROM can be included on the device. The Vinculum can host 2 game controllers as well!
The Vinculum can be reconfigured through the UART and an on-board boot program as well.
In sum, the hardware is all there. We just need a Vinculum/USB Game Controller work group to evolve firmware and programing proceedure.
Andre'
That won't work. The Hydra's USB connector is for a USB to serial adapter which can't be used as a USB host. The only thing you can plug in there is a cable to a PC (host controller). The same thing is true for the PropPlug / PropStickUSB / Demo Board / USB2SER / Protoboard, etc. The only USB host controllers available that would easily work with the Propeller are the Vinculum and GHI Electronics units.
Andre'
I was watching a research vessel using and underwater ROV on either the Discovery or National Geographic channel recently.
Low and behold, the operator was using a Sony Playstation II set to control this quite exotic and expensive device. I realized that I really don't need to spend money on DIY joysticks and such to get the kind of device that really can do such tasks. There are many off-the-shelf devices that will do just fine -- if they can talk to the Hydra or Propeller chip.
In actuality, any game HID device would be useful not only for games, but for remote control, robotic work, and/or graphic rendering.
I will consider the possiblity of using the existing USB slave port, but it would be nice to have a pair of USB hosts available for games. Also, I see now that the PS/2 appears to be not the same as USB. If PS/2 is easier, more direct; I guess that is the way to go.
Andre'
The Viniculum includes a microcontroller within its package, but I cannot seem to currently find any public documents on programing. They appear to be conservative and hush hush. It may be they service the industry and don't want the public hacking their products.
I did look at the various HID USB devices and there are a lot. Most are copies of the Sony DualShock. Some feature analogue joysticks [noparse][[/noparse]same as Sony]. Since there are also about 10 buttons on these, I look forward to one day having a way to integrate them with the Hydra.
I think a USB driver for the propellor would be as big a step as the Hydra itself. The propellor would be able to communicate with Flash Drives, Microphones, USB mice, USB keyboards, wireless Adapters, webcams(might be too fast?), and almost anything. Considering that the world seems to be moving towards USB I think it is a must for a propellor interface.
ACfishing
The issue is allocation of resources. The current Propeller has 32K of main memory and a couple of K of cog memory. USB hosting is complicated. On top of the low level USB code (which runs quite fast, particularly with USB2.0) each I/O device has to have a driver. At the very least, you're talking about devoting pretty much a whole Propeller to just handling USB. A Propeller with some basic external circuitry (like the Protoboard) costs about $25 dollars in small quantities. A complete USB host with I/O drivers for common devices (mass storage, HID, and serial I/O) can be bought for roughly twice that. This includes amortized development cost and these are commercial products with support available.
It's really hard to justify doing this with a Propeller when you can buy someone else's tested version.
To compare ... I've been using Rokicki's FAT file driver on the Propeller. It's very nice, very cheap (just need an SD card socket). On the other hand, it takes quite a bit of memory to implement. It's a very incomplete implementation. In particular, it doesn't support directories at all while most commercial SD card interfaces do support them. Keep in mind that USB hosting is much much more complicated.
There are a few sites out here that are reverse engineering these controllers. The biggest issue so far seems to be enabling the motion detection features. See http://www.wiili.org/index.php/Wiimote and http://www.dcemu.co.uk/vbulletin/showthread.php?t=45209
I will be using the same controller to play games on my HYDRA clone and to control my Propeller run Bioloid robot.
I have considered merely hacking a GameController to deal with a simple synchonous serial interface.
The only reason to go the USB route is that there is a wide selection of DualShock and other game controller devices that use the interface. I was thinking that the USB interface would broaden the user base for the Hydra and the Propeller as many overseas locations do not have all the variety that the USA has.
For instance, being in Taiwan I can no longer buy a CRT display over the counter at any of the local stores - only flat screen. I know that may seem odd, but the huge inventories are or were exported to companies like Dell. When innovations occur the old stuff is quickly gone or sits around forever.
