Parallax Gas Robot in R&D - Page 2 — Parallax Forums
2»
  • slamerslamer Posts: 52
    edited 2007-02-28 00:12
    Impressive! Hydrostatic drive on a small robot. That's very cool stuff!
    It's really amazing you got it down to 75 lbs! I'd like to see a video of it doing it's stuff. My Father and I have built several gasoline powered radio controlled combat robots in the 220 to 340 lb weight range. If you notice RF interference problems from the engine's ignition system Resistor spark plugs help out this problem a lot. It also helps to keep the control electronics as far from the engines ignition system as possible and using sheilded wiring for your I/O circuits is a good idea as well. Great looking machine Man...
    undefinedundefinedundefinedundefined
    edited 2007-03-21 16:52
    Hello Everyone,
    Development continues and Ken has brought in some new pictures for me to share with everyone. Here’s a little something to whet your appetite...7 new photos of the Gas Powered Bot. Enjoy!
    Chris Savage
    Parallax Tech Support
    648 x 486 - 53K
    648 x 486 - 59K
    648 x 486 - 61K
    648 x 486 - 66K
    648 x 486 - 59K
    edited 2007-03-21 16:53
    And the last two...
    Chris Savage
    648 x 486 - 62K
    648 x 486 - 67K
  • Brian_BBrian_B Posts: 842
    edited 2007-03-21 16:56
    AWSOME !!!!
    Thank's Brian
    www.truckwiz.com
    ·"Imagination is more important than knowledge..." ·· Albert Einstein
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2007-03-21 17:34
    It must be more than a Co-Winque-A-Dink,lol
    Goped tires and brakes, either Ken is·stripping down·the goped that's sitting in the garage colecting dust or Somebody knows the Patmonts??
    If there's still a goped left alive, gopeds are for riding and put one of my "Stinger" pipes on it!!
    edited 2007-03-21 17:51
    Capt. Quirk·your assessment is incorrect. The gas robot has practically nothing in common with a go-ped. While both derive thier power from a gas engine, that is where the similarity ends. This robot uses the engine to drive a hydraulic system which is what drives the wheels, the go-ped does not use this technique. Rubber tires designed for off-pavement of comparable size all look alike. The machine shop who built this for us creates custom scooters, perhaps this is where you are seeing similarities.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 3/21/2007 7:30:21 PM GMT
    edited 2007-03-21 17:54
    Trevor?
    Post Edited (Capt. Quirk) : 3/21/2007 9:36:36 PM GMT
  • Paul Sr.Paul Sr. Posts: 435
    edited 2007-03-21 18:21
    Now that's a thing of beauty!!!
  • Jim RicheyJim Richey Posts: 82
    edited 2007-03-21 23:39
    What an unbelievable piece of machinery.I can only imagine the hours
    of dedicated labor that you dedicated to it's becoming reality.The craftsmanship
    that shows throughout rivals a NASA creation.I'm going to smash my machines with a big hammer and start over again after seeing this!
    Best wishes
    Jim Richey
    Thanks, Parallax!
    edited 2007-03-22 04:09
    Are you guys really shooting for a $2000 price tag ? or did sombody leave off a zero.
    Thank's Brian
    www.truckwiz.com
    edited 2007-03-22 04:34
    Hey guys,
    We didn't design this machine - we hired a local engineering/machine shop and told him what we would like it to be able to do. The firm that built it also makes really high-end gas scooters - not the kind you see from China but really precise, 100%-machined, artistic scooters. He's certainly got more mechanical than electrical experience, but now he's learned to use a BASIC Stamp so he can test the subsystems on this robot. We figure we can put the Parallax specialties together with his mechanical skills and design a unique robot.
    We are shooting for $2000 price tag or less, but every time we meet with this engineer it seems to get a bit more expensive. I'm a bit overly optimistic about some things. I told our forum members that the Prop Proto Board would be well under $20 (or did I say $15?) and they sell for $20-25. Applying the same error ratio to this big robot, maybe it'll be more around $2500. It's expensive, but let's face it that the volume is low so it's tough to optimize the design and move away from machining and towards other alternative methods of fabrication that involve tooling, steel, welding, etc.
    We may never recover our costs, or at least in the first three years.
    We're going to stick with this project.
  • Philip GamblinPhilip Gamblin Posts: 202
    edited 2007-03-22 05:07
    now that the hydraulic frontier has been breeched, how about a PTO?
    edited 2007-03-22 06:14
    No offence intended, But Shops like that and Production don't mix.
    Besides that, If you spent 9 to 12 months of additional R&D and design changes or _more.·Find the right vendors, have your marketing in the right place. 20 to 25 shouldn't be necessary.
    Again, No offence intended. It's just a topic within a public forum.
    Quirkis Maximis
    edited 2007-03-22 15:07
    Ken,
    Thanks for explaining how the machine was built.I didn't realize that it was
    done on a professional basis.I can't imagine having the talent to produce something so beautiful.Wouldn't it be a shame to take it out and beat it up to it's potential? Wow!
    Best regards,Jim Richey
    Thanks, Parallax!
