Screw Shaft
Anyone know where I might be able to purchase a shaft with a coarse screw thread. Somewhat like what a C clamp would have. Perhaps a length of a foot to a foot and a half long.
I've done searches on ebay with no luck. Perhaps I'm using the wrong search terms. Would there be a better name for it?
Thanks in advance
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
Thanks in advance
Brian Meade
I've seen 1/10th of an inch pitch All-Thread rods, but it sounds like you are looking for something closer to 1/5th inch pitch or something.
Here is a Google link: "All-Thread" Rod ...
www.portlandbolt.com/products/rods/allthread_rod.html
...There are several others you will just need to comb through.
Beau Schwabe
IC Layout Engineer
Yoou are probably looking for what's called "threaded rod" or "Acme screw thread". The latter is used for linear actuators.
If you give us a bot more information about the application perhaps we can recommend a source.
Bruce Bates
<!--StartFragment -->
Tons of stuff like this at www.mcmaster.com
Cheers,
Peter (pjv)
What pjv said: McMaster-Carr.
--Bill
You are what you write.
acme thread ,
www.mscdirect.com
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
McMaster has exactly what I'm looking for. the "Acme Threaded rod"
as the description says - "...Converts rotary motion into smooth, precise linear motion."
I want to connect the shaft of a stepper motor to this to form a simple CNC type machine.
I'll check out of of those other websites also to find the best price, but McMaster looks reasonable.
Brian Meade
There is a guy that makes Delrin acme couplers and anti backlash nuts as well, he has even built custom acme nuts and couplers:
www.dumpstercnc.com/
One very important consideration when designing a CNC machine is backlash. Make sure that the leadscrew and nut combination has some way to take up (i.e. minimize) the backlash, yet remain stiff enough for the type of CNC work you're doing. Some spring-loaded leadscrew nuts will eliminate backlash for light-duty apps, such as moving printheads, but won't be stiff enough for machining. Ballscrews are the best, but they're quite expensive.
I've bookmarked them, there was all sorts of goodies at all of those sites! I saw solutions to problems that I don't even have yet!
Brian Meade
