Does SHIFTIN/OUT 'Speed multiplyer' function?
Steel
Just in testing a DAC with my SX28 and the SHIFTOUT COMMAND, I have changed the Speed Multiplier from 2 to 5000 .·
No matter what multiplier I choose, It takes the same amount of time to transfer data.
Are there any known bugs with the speed multiplier, or am I just seeing an anomolie?
Shaun
Shaun
At what speed are you clocking the SX ?
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Can you post your code ?
Bean.
Shaun,
· If you look at the generated assembly code you will see that the SHIFTIN if faster (the delay is controlled by __PARAM4) , but the other commands overshadow the speed increase.
· I suspect the SERIN command after SHIFTIN is causing the hold-up.
Bean.
Post Edited (Bean (Hitt Consulting)) : 2/27/2007 12:01:13 AM GMT
