K I think i need more memory?
I am doing a competition, micromouse. If you haven't heard of it just search it on google. but I need to be able to store the map in memory, I probably could store it in EEPROM but It might right to it a lot and read from it alot so I don't know if it is a good idea. I have a BOE bot with BS2. I am thinking about getting a javelin, which would be enough memory.
Ok this is probably what i need for memory 256 bits for vertical walls and 256 bits for horizontal walls.
If possible maybe even make a weighted map, but that would mean I would need 256bytes of more memory.
would this be possible to do on BS2 with EEPROM or should i just get the javelin? i am thinking just get the javelin especially if I use the weighted map, because it would need to rewrite a lot. but if I just store the walls in memory I could probably just use the BS2 but what do you think?
The Javelin would be a much more 'brag-worthy' solution. Future employers would be fascinated by a Java-based micro-mouse, where they'd ho-hum a Basic-based mouse.
