DPDT relay with off postion?
Does anyone know where I can get a DPDT (double pole double throw) relay with an off position? I know you can get switches like this with a center off position but didn't know about a relay. I want to use it for a project, using a remote control car that has differential steering, to control one of the two motors. I don't even know if something like this is made but maybe one of you guys have seen it.
Such DPDT C/O relays have two coils. One coil actuates the armature in one position or direction, and the other actuates it in the opposite position or direction. If neither coil is actuated, the relay self-centers for an "OFF" position.
More information can be provided, if you provide some specifications. The primary concerns here are voltage, amperage and mounting.
Bruce Bates
<!--StartFragment -->
NerdMaster
For
Life
http://www.robotcombat.com/marketplace_teamdelta_rc.html
These fine products are made by Team Delta...
http://www.teamdelta.com/
Team K.I.S.S
Build Safe, Build Mean, Build Strong!
