Weird Problem: BS2 + Devantech CMPS03 Digital Compass.
I'm trying to·interface the CMPS03 compass with a BS2·on a Board of Education.
I downloaded the demo program from:
http://www.robot-electronics.co.uk/htm/cmps2bs2.shtml
The Compass Bearing·can then be shown on the debug window.
For the first 1-2 minute:
I got:
Compass Bearing (0-255 BRAD) 060
Compass Bearing (0-359 Degrees) 085
When I turned the compass, I got some other values that make sense.
But then,·(after around 1-2 minute; sometimes, several seconds)·I got the following values in the debug windows:
Compass Bearing (0-255 BRAD) 255
Compass Bearing (0-359 Degrees) 533
And the values do NOT change ANYMORE no matter to which direction I turn the compass.
In order to reset the whole thing, I gotta power off the circuit, download the program to BS2 again and run the program again.· Sometimes I needa repeat this procedure for several times before the compass gives values that make sense.
I notice that everytime when the values begin to oscillate between two values, say 085-087(Degrees)... It gets a higher chance to turn to 533 and stays there.
What's the cause of it???
Hardware problem? Software problem? Wiring Problem?
What should I do to fix this problem??
By the way, I have disconnected all other components from the BS2.· I just connected the compass with its circuitry to the BS2.
Please help! Million Thanks!!!!!!
Post Edited (koolitude) : 2/26/2007 6:15:09 PM GMT
I got:
[noparse][[/noparse] Subroutines ]
GoCap:
DO
pause 250
GOSUB ReadBoussole
IF angle > consigneCap THEN
errCap = angle - consigneCap
ELSE
errCap = consigneCap - angle
ENDIF
IF errCap < errCapPermise THEN
RETURN
ENDIF
DEBUG 2,0,0,"Consigne :", DEC3 consigneCap, " Compas :", DEC3 angle, " errCap :", DEC3 errCap
i = i +1
IF consigneCap < 180 THEN
IF angle > consigneCap AND angle < consigneCap+180 THEN
DEBUG 2,0,1, "Gauche"
GOSUB gauche
ELSE
DEBUG 2,0,1, "Droite"
'GOSUB droite
ENDIF
ELSEIF consigneCap >= 180 THEN
IF angle < consigneCap AND angle > consigneCap-180 THEN
GOSUB droite
ELSE
GOSUB gauche
ENDIF
ENDIF
LOOP
ReadBoussole:
devNum = 0 ' device address %000
slvAddr = CMP03 | (devNum << 0) ' setup slave ID
addrLen = 1
wrdAddr = 1 ' addresse compas sur un octet $00->$FF
GOSUB Read_Byte
angle = i2cData
DEBUG 2,0,2, "cmp :", DEC3 i, " angle :", DEC3 angle
RETURN
GoCap:
DO
pause ' <
if not add this pause, not work perhaps is your PB
GOSUB ReadBoussole
ELSE
ENDIF
RETURN
ENDIF
i = i +1
GOSUB gauche
ELSE
'GOSUB droite
ENDIF
GOSUB droite
ELSE
'GOSUB gauche
ENDIF
ENDIF
LOOP
ReadBoussole:
addrLen = 1
GOSUB Read_Byte
angle = i2cData
RETURN
By the way, some symbols and subroutines are not defined in your program...
What are they exactly?
Anyway, Thank you very much!
Post Edited (koolitude) : 2/26/2007 11:34:34 AM GMT
