propeller text editor
LucidGuppy
I don't know if this should go into the object exchange but I've come up with a prototype text editor along the lines of vi - I call it pvi. Try it and let me know what you think.
hjkl for navigation
i to enter insert mode
caps_lock to escape insert mode - back into command mode
so far thats all I have - but I would like the editor to output to a buffer onchip somehow, a command to output to a serial port, and some other stuff - I'm still working on that. Right now it only sort of acts like a vga typewriter.
You have to edit vga-text object so it doesn't pop a newline if you are at the last column.
...from VGA_Text.spin
Post Edited (LucidGuppy) : 2/25/2007 11:09:37 PM GMT
hjkl for navigation
PRI print(c) screen[noparse][[/noparse]row * cols + col] := (color << 1 + c & 1) << 10 + $200 + c & $FE 'got rid of this because I need that last row... if ++col > cols col-- 'if ++col == cols ' newline
escape key?
en.wikipedia.org/wiki/Vi
then you see escape was alot closer to the home row. Its the setting I use when I run VIM, and honestly - does anyone use caps lock all that often?
change, right? Anyway, thanks a lot for this; I have been wondering whether I should try to write it, and it's
nice that someone else got there before me!
If you want to use LISP-like cells, you could use a long for each like
sometimes 2x, sometimes 1.5x, whatever works). All text before the cursor position is at the front of the buffer; all text after
the cursor position is at the end of the buffer. When you type, you just insert where the cursor position is in the buffer. When
you move the cursor, you move a chunk of text (however big the move is) from the bottom to the top or vice versa.
It's very simple, wastes no memory, and you only end up doing big memory moves when the user does huge scrolls (to the top or
to the bottom of the file). Its very simplicity makes it very effective for small systems such as the Propeller, where every byte
of code you save is another byte of text file that can be edited.
Of course this can be adapted for files that are paged to disk and so on.
I find it much easier to deal with than linked lists of lines.
var
byte textfile[noparse][[/noparse]MAX_SIZE]
long bytesused
at the start, you initialize bytes used to 0, and fill textfile with 0's
do NOT allow 0's (nulls) as a valid character in any line
every time you add a line, add the length+1 to bytesused
when you delete a line, move everything up, and subtract the deleted length+1 from used bytes
why keep track of used bytes? so you can add to the end quickly; its not really needed, as you can chain along the various lengths to find the end - or any line - quickly
then you just have entries, one after the other, in the following format:
[noparse][[/noparse]line1#bytes] ... text1 ... [noparse][[/noparse]line2#bytes] ... text2 ... .... .... [noparse][[/noparse]lineN#bytes] ... textN ... [noparse][[/noparse]0]
char(8) is already tab, but you can save a LOT of space in the buffer by using the following convention:
char(1..7) = one to seven spaces
char(8) tab = normally 8 spaces
char(9..31) = 9 to 31 spaces
The beauty of the above is that any ammount of indentation will only take one line, and spaces separating arguments or comments will also likely only take one byte. This scheme does limit you to a minimum of one and a maximum of 255 characters per line.
www.mikronauts.com - a new blog about microcontrollers
