Duty mode output to drive Power MosFET or IGBT
Hi
I am trying to use the 60Hz sine wave duty mode output to drive MosFET or IGBT. The minimum pulse width needs to be 10 uSec or higher otherwise those power devices can't catch up. How to limit the minimum pulse width to 10 or 20 uSec?
Thanks in advance.
Ching
Thanks in advance.
Ching
You'll probably have to dedicate a cog to a software PWM routine. The counters' DUTY mode pulse widths, at reasonable system clock frequencies, are just too short for driving MOSFETs, forcing them to spend too much time in their linear region and possibly overheating.
Essentially I am just using Tracy Allen's "sinewave0.spin" code.
I am using DUTY single-ended for now, in real application I will need to change to DUTY differential to drive a full bridge.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 bits = 9 VAR long apin, afreq PUB main apin := 0 ' Pin0 - square, Pin1 - sine afreq := 3221 ' Frequency 60 Hz cognew(@entry,@apin) ' load the pasm into a cog with par pointing to apin location DAT org 0 entry mov ptr,par ' ptr to paramters rdlong pn,ptr ' read in the pin to use add ptr,#4 ' point to next parameter rdlong frqa,ptr ' read in the frequency parameter or amode,pn ' amode is a cog consant for NCO mode, OR in the pin number shl cat,pn ' this will be the mask to set pins pn and pn+1 as outputs add pn,#1 ' next pin or bmode,pn ' bmode is cog constant for duty mode, OR in the pin number mov ctra,amode ' counter A set to NCO mode tied to pin pn mov frqb,center ' this is the 50% duty for counter B in duty mode mov ctrb,bmode ' counter B set to duty mode tied to pin pn+1 mov dira,cat ' set pins used to output mov T,cnt loop add T,dT waitcnt T,dT mov phx,phsa ' main loop looks at counter A phase shr phx,#19 ' shift to make it 13 bits for full circle call #getsin ' find sine of phase shl phx,#15 ' it returns 16 bits signed, make it 32 bits +/- $8000_0000 add phx,center ' offset to center, 0 to $ffff_ffff (actually $1_0000 to $FFFE_0000) mov frqb,phx ' update duty of counter b add ptr,#4 wrlong frqb,ptr jmp #loop getsin test phx,sin_90 wc 'get quadrant 2|4 into c test phx,sin_180 wz 'get quadrant 3|4 into nz negc phx,phx 'if quadrant 2|4, negate offset or phx,sin_table 'or in sin table address >> 1 shl phx,#1 'shift left to get final word address rdword phx,phx 'read word sample from $E000 to $F000 negnz phx,phx 'if quadrant 3|4, negate sample getsin_ret ret ' (this subroutine adapted from Prop manual) sin_90 long $0800 sin_180 long $1000 sin_table long $E000 >> 1 'sine table base shifted right, because program does *2 to convert to word addrs center long $8000_0000 amode long %0_00100_000_00000000_000000_000_000000 'NCO mode bmode long %0_00110_000_00000000_000000_000_000000 'Duty mode cat long 3 dT long |< bits - 1 phx res 1 ptr res 1 pn res 1 T res 1Thanks,
Ching
Phil,
I thought about using another cog in logic mode to extend the timing slot too, but I am new to this and unable to come up with any scheme.
Ching
You might try right shifting the FRQB value 9 bits before loading it into FRQB. This would slow down the duty cycle by about a factor of 500 from about 25ns to about 12us at midpoint.
Please correct me if I've misunderstood something here, but I've always assumed that DUTY mode outputs could never be used as a substitute for PWM when driving MOSFETs due to the extremely narrow pulse widths.
Phil
Post Edited (Phil Pilgrim (PhiPi)) : 2/22/2007 10:01:27 PM GMT
I had the "mov ptr,PAR" at the assembly entry and I used "add ptr,#4" & "wrlong frqb,ptr" for debug only that I forgot to delete them.
The output sine wave disappear after I insert "shr phx,#9" above "mov frqb,phx". Did I miss something else?
Ching
:loop ' You could put the sine calculation here mov temp,#1000+8 ' Total time (+ minimum) sub temp,value ' Compute the difference add temp,cnt ' Add in system counter waitcnt temp,#0 ' Wait for that time xor outa,bitMask ' Toggle the I/O pin add value,#8 ' Adjust for minimum time add value,cnt ' Add in system counter waitcnt value,#0 ' Wait for that time xor outa,bitMask ' Toggle the I/O pin jmp #:loopEssentially this takes a value between 0 and 1000, sets a minimum width of about 250ns and a maximum width of about 12.75us with a repetition rate of about 25us. You can add the sine calculation for the 0-1000 value and use the extra cycles to increase the minimum on time.
Is the issue that no individual dwell time (high or low) can be less than 10 microseconds? If that is the case, Mike's scheme, like the DUTY scheme would still be too fast.
In 1/60 of a second there are only 1667 intervals of 10 microseconds.
My first thought was to use a hardware pulse stretcher with the DUTY output, to create a 10 microsecond pulse out of each 12.5ns DUTY pulse. The dead space between each DUTY pulse would have to be longer than 10 microseconds. With clkfreq=80mhz, there are 800 clocks in one 10 microsecond interval, so FRQb<5368709 would be the condition, and the sinus could modulate up to that limit. An external pulse strecher is not a very nice solution though.
The Prop should do it on its own. I'm thinking of a lookup table of output state vs phase, something like Don Lancaster's magic sine waves.
Tracy Allen
www.emesystems.com
Where is your 10us value comming from?
Graham
No, LOW can be much less than 10uS.
The Prop output will be connected to a 600V high and low side driver. A pulse strecher is something worth considering for us.
Ching
Graham,
It is a high voltage application, 10us mainly comes from the consideration of power conversion efficiency.
Ching
Mike's approach looks like a good one, proper PWM.
Graham
Modelling in the frequency domain does have the advantage of not having to consider the filtering until after the fact, but computing the error function for each candidate pulse stream is more computationally complex.
I'm going to start another thread for the magic sine waves. It might be relevant for Ching's question, but it is topic in itself. I think it might be relevant because the magic sine waves (to borrow Graham's words) "ensure the switchings are sufficiently infrequent for low power loss". It appears that the magic sine waves are intended as an improvement on standard PWM techniques, primarily for driving motors in a bridge configuration.
Tracy Allen
www.emesystems.com
