Using EEPROM for storing values.
I have a BOE-BOT..........can someone help me out whether i can use the EEPROm for storing values instead of usual variable declaration............If possible how can I read / write my values thru this procedure.........
Post Edited By Moderator (Chris Savage (Parallax)) : 2/22/2007 10:40:25 PM GMT
Why, what is the problem you're having?
Oh, also note the EEPROM is limited to 1 million writes. This isn't a problem if programming it, or writing once a day, but would be a problem if writing it once a second.
