Converting BS2 program to BS1
Hi
I have what I suspect is a stupid simple question. Forgive me, I'm not a programmer at all, I'm looking this up as I go along. I have a code that works fine in the BS2. It does this:
Main:
IF IN1 = 1 THEN SUB1
IF IN3 = 1 THEN SUB2
GOTO MAIN
That's it; 1 and 3 have draw downs to vss, to hold them low. When they see a high input they go to the required subroutine. Works great.
Now I'm trying to make it work on a BS1. But the BS1 doesn't like IN1 =1 in an IF... THEN loop, it tells me it's an undefined symbol. What's the easiest work around for this?
thanks,
K O'N
Main:
GOTO MAIN
thanks,
K O'N
Please refer to the pin names for the BS1 in the memory section. They use PIN0 through PIN7 rather than IN0 through IN15. Take care.
Chris Savage
Parallax Tech Support
Thanks, Chris. That's fixed it.
Kevin
