Custom Prop board — Parallax Forums
Custom Prop board
OwenOwen Posts: 100
edited 2007-02-18 19:27 in Propeller 1
I'm building a custom prob pcb board specificaly for a project of mine that controlls a large SLR camera. This is my first time designing a pcb and using Eagle and I was hoping some one in the forum would be able to give me feedback on the design. My design is based off the demo board and the DLP Prop so i'm not really doing anything new here it's just that I don't have much experience in this area yet. As a note the clock signal comes from the ft232r CBUS0 just like it does on the DLP Prop, and the motors i'm using are steppers. if anyone has the time I would love the feedback.
Owen
  • T ChapT Chap Posts: 4,260
    If you have named a label on the pins, and then add the same label/name to a net, it is not necessary to draw the bus, the connections are already made, so the bus is redundant unless it is for visual only.
