load cell
I have a load cell I'm trying to read with a BS2.· The cell has a four wire lead, two for a 10 VDC excitation voltage and 2 for output.· The output is rated at 2mv/V.··So I believe that at 100% capacity the cell will output 20 mv (10V x .002).· Total range of the output is 0mv to 20mv
After great deal of research I think I should be able to use an op-amp to scale the voltage up to the 0 -5v range that I could use the LTC1289 ADC to read the voltage and·translate the voltage reading to·the weight on the cell.· I have the details of the ADC but I need some direction on the op-amp portion of the circuit.
Any suggestions or pointers to reference material would be greatly appreciated.
The AD524 is a good, simple one with adjustable gains of 10, 100,·1000.· Do a search at www.digikey.com, and 'fairly cheap' at $16.· You can build an amp yourself with 3 op-amps, and·it's discussed in Parallax's "Process Control" text, but a good packaged one ensures very high precision resistances for good noise cancellation.
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Search the forum for AD7730 you will find example code.
