basic stamp and I2c bus
HI,
I am new to the basic stamp. I am retired and have decided to build a robot. I have completed the platform and run it around using a joystick no problems ( it weighs in at 200lbs. ). In looking around for the proper brain for it I have looked at the Oopic and basic stamp. When I came across the add for the MSRS Boe-Bot I decided go that route to get my feet wet. I have run the Boe-Bot all around the house using my laptop and MSRS. Now I am ready to move on and transfer to my large robot.
My problem is I want use the CMPSO3 electronic compass and from what I understand I need to use I2C bus for the compass. I know I will have to purchase the BS2P stamp for that but I can not determine if I need to replace the board of education or not in order to use I2C bus. Any help greatly appreciated.
It IS possible to make an I2C bus with a 'plain' BS2, but the BS2p does have special commands for it. Meaning it would take more code and work more slowly in a 'plain' BS2.
Thanks for the reply. It looks like my best bet is to buy the BS2P and use it on my BOE. I looked a little closer at the BOE doc and believe I now understand now.
Thanks ED
the CMPS03 also has a PWM output with pulse width proportional to heading.
a few lines of code make it easy to interface with your Stamp, and I've found the output to be just as accurate as the I2C method.
here's a code snippet provided by the manufacturer for the different available Stamps:
further explanations here:
www.robot-electronics.co.uk/htm/cmps2pwm.shtml
