SX trouble
Several students in my program have purchased clone bots with BS2sx chips...when we assembled them, we all have the same trouble...the stamp editor doesn't see the stamp...it returns a "yes" to loopback and echo...
All of the voltage checks are good on the board, and several of us have the same problem...
Is it possible that the resonator is causing us grief (50mHz), or is there some way we can rule this out?
This thread is being moved from the SX Forum to the BASIC Stamp Forum.· What version of the BASIC Stamp Editor are you using? V2.2.6 is the latest.
Chris Savage
Parallax Tech Support
You may need to provide more information about what you have including a schematic. There may be a power/noise problem. Although it's possible there is a faulty resonator, it would be unlikely to have several fail. Most likely it's a power or wiring problem. The voltages may look ok on a meter, but there may be noise pulses or other transients.
the schematic is at : http://www.budgetbot.com/downloads/CBAMB_Sch.pdf
seems straightforward, and we all have the same problem. We have tried updated software, new cables, USB to Serial.....
no luck for any of us.
any input is very welcome.
Rick
I don’t know if the schematic is correct at all…It shows a 24LC16 EEPROM which is incorrect for a BS2e or BS2sx…That EEPROM is for the stock BS2 only.
Chris Savage
The board has a sx28ac/dp-g stamp, and a 24lc128 EEprom.
tanj@zapper ~/bstamp $ bstamp_run hw.tok Error: No BASIC Stamp identified! Probably the stamp isn't connected, perhaps your stamp version isn't supported? Try looking at the help, try 'bstamp_run -h' for more information.
the source I tokenized
'{$STAMP BS2sx} '{$PBASIC 2.5} DEBUG "Hello World!"
my guess from the error message is that the information for what kind of stamp is on the board is not getting through. Is this imformation in EEPROM? where is it? How is this information communicated to the software?
There are versions 1.16 and 1.23 both available. Check to make sure which one you have. I suspect you want 1.23.
The Stamp interpreter that's programmed into the SX-28 knows which model it is and communicates with the PC shortly after the chip is reset (forced by the serial channel being opened and DTR pulsed) as part of the identification sequence.
The EEPROM just stores the byte codes for your program.
tanj@zapper ~/bstamp $ bstamp_tokenize hw.bs2 hw.tok PBASIC Tokenizer Library version 1.23
tanj@zapper ~/bstamp $ bstamp_run -h Basic Stamp Linux Programmer / Debugger This program is used to program and run a basic stamp. Before it can be used, some simple setup must be done (see below). For more information about the Basic Stamp, see http://www.parallax.com This is a modified version of bstamp available at http://bstamp.sourceforge.net Options: -h or -? : this help listing -v : the program version -a : about the program (brief history) -s : use stdin instead of INFILE.TOK alternately, to use stdin do not include any other arguments. The basic stamp must be plugged into a local serial (COM) port. Examples here use /dev/ttyS0 as the serial port,. but you may need to use something else (like /dev/ttyS1). A symlink named 'bstamp' in /dev must point to the com port you wish to use. This can be done with 'ln -s /dev/ttyS0 /dev/bstamp'. If the serial port doesn't work, you might try 'MAKEDEV /dev/ttyS0' You may need to be root to accomplish this, try 'su' to become root. When done with MAKEDEV and creating the symlink, type exit. You must include a tokenized program when calling this program. First run 'bstamp_tokenize INFILE.TXT OUTFILE.TOK' to make the tokenized program. Next run 'cat INFILE.TOK | bstamp_run' Standard Usage: bstamp_run INFILE.TOK Or: cat INFILE.TOK | bstamp_run Or: cat INFILE.BS2 | bstamp_tokenizer | bstamp_run
This problem we are having is hardware (BS board itself) or in assembling it somewhere.
We are trying to discover the source of the hardware problem.
Thanks for the suggestions so far
But I assume you have an SX chip that is programmed with the Stamp Firmware ?
If you are just using an SX28AC/DP that has not been program by Parallax, it will not work.
Just an idea
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Hope this helps,
Robert
The capacitors were added a couple of years ago. I don't think they were needed under DOS and early Windows versions.
Is there a way to ring out the chips to determine if they are faulty? They were shipped from US to Canada via the postal service....it is safe to assume that they were exposed to low level xrays....
Not all Parallax SX chips have the basic interpreter in them.
Here is the one you want http://www.parallax.com/detail.asp?product_id=PBASIC2SX/P
Here is the one that won't work http://www.parallax.com/detail.asp?product_id=SX28AC/DP-G
Notice the difference in price. This has come up before, people just get the SX chip and think it will make a basic stamp.
Bean.
Sorry I didn't see the advert. Most likely not the problem then.
Bean.
Truly Understand the Fundamentals and the Path will be so much easier...
one of the students in the class assembled their kit, and it works perfectly...
He graciously agreed to let us swap some chips....his sx worked in a non-working board, and a non working chip didn't work in his....when we changed them back, all was well.
It looks like we have a lot of bad sx chips.....
Can they be re-flashed, or are they sinkers?
Post Edited (Mike Green) : 2/14/2007 5:07:36 PM GMT
Nice to know there's a place to look......
