One-way potentiometer
Where can I find potentiometers that start at zero resistance and increase all the way to its value in one direction.· For example a normal 100K pot will be zero resistance in the center and be 100K fully·counterclockwise and the same clockwise.· For me, just one way.· Where·is·a mouser part number for a·one that is·5K?
I don't know of ANY pot that is zero ohms when centered ?
I think you just want a normal everyday pot.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
You could combine an ordinary pot in series with a tunnel diode (remember those?). The resistances would add so you'd have positive resistance at one end, zero in the middle, and negative resistance at the other. How about that?
(Sorry I couldn't resist. originator, look up tunnel diodes and negative resistance on the Wikipedia. I'm sure you'll find some information. It's not what you might think.)
