Baja 1000
Beau Schwabe
I just thought I would throw this out to see what kind of ideas it would generate.
I ran into a guy this evening at a birthday party that my daughter had been invited to·that races in the Baja 1000 every year.· Anyway, one of the things that he wants to do is equip his vehicle with 24/7 video capabilities throughout the entire race.· One of the big problems is finding a video camera capable of surviving up to 5g's throughout the journey.·· ...Similar to what 'micron' is doing, only he doesn't have a big sponsor like Micron so he can't shell out the $$ for the image sensors they are using... (http://www.micron.com/baja1000/) Another issue is storage space for that much video...· Typically it takes his team 32 hours to run the race. (<--Teams are given 40 hours to complete the race)· The camera should also be sensitive to night video with a light source only from the vehicles headlights.
At this point what I would like to get a better grasp on is what kind of video options are out there capable of capturing a continuous 115,200 seconds and able to withstand·up to 5g's.·
Obvious other things along the way would be to include GPS, Speed, Engine RPM, accelerometer data, etc. either superimposed on the video, or recorded separately with a synchronous time stamp.
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
a single board computer booting off solid state memory(ive heard of a 90mb winxp that can boot off flash drives) and a bunch of 4-8gb USB thumb drives?
3D & 2D Design - Technical Documentation
www.robertguyser.com
Yeah, that's about what I told him. He did mention that he would be willing to sacrifice video resolution just to get a complete video of the race from the car's perspective... but still.
Even at 176x144 NTSC if you use 8-bit color resolution that's 203k per frame...Assuming 30fps that's 6.1Megs per second x 115,200 seconds = 703 Gigs!
I was hoping for a video compression solution.
Beau Schwabe
IC Layout Engineer
The hard part might be finding a heavy-duty camera and transmitter.
Trying to help!
Post Edited (Desy2820) : 2/12/2007 10:14:39 AM GMT
I thought about transmitting the video, but because of the distances involved and the obstacles on the track there is no way that a chase vehicle would be able to stay within range.
Beau Schwabe
IC Layout Engineer
You got a "co-op" of a number of participants together, and possibly some HAM Radio groups, and found a way to set up a system of "repeaters".
This could be an interesting project for one of the national/international groups like ARL or MARS or someone like that. I'm not a "HAM" but I've known some, and given the right group of guys, and rigth circumstances, they'd eat this up.
John R.
Click here to see my Nomad Build Log
Why go 30fps? IF it's good enough quality, why not go with 15fps.... Or less.
During daylight, a series of still pictures would probably be fine. But auto-exposure for night time pictures means the shutter is left open longer and you'd end up with a blurred image (light streaks).
Hasn't someone in the propellor area hooked up a CCD yet? Then just write to a few large flash drives? hehe..sorry to trivialize it.
Whatever you create....right it off! These guys wipeout and then push the car back on it's wheels and keep going...so anything you mount will probably be gone!! hehe
Go with either a flashbased camcorder with shockmounts or an old digital camera taking timed stills. Have a single board computer connected to it to download the images to a flash drive. I think the best you could do with timed stills is 1fps (using preset focus settings).
Some digital camera's have movie modes that only run at 15fps. (I just got an Olympus 720SW that is shockproof wrt a 5ft drop...not sure how that equates to G-forces..but I'd think more than 5 with it's weight and all).
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
I think you can do better than that. a e hour divx at surprisingly good resolution is about 900mb - that is more like 30-40gb. this is easier t accept. another idea could be to didassemble an oldish laptop(1ghz range), put a beefy hdd in it, wrap it in foam, and put it in a padded attache case.... glue all the connectors...
clearly i havent got usefull suggstions and wil stop now!
Yup, and with a good AP and a high power amp, and several pre positioned recievers, you could do it...
BTW, the laptop hard drive route might work, but you will have to be darned sure you mount the hard drive
in a suitable shock proof enclosure...
I would personaly use a micro-nano-atx mob with 1 gig memory,
and a 120W pico-power supply in a custom case...
That way you can use off the shelf components (vid capture card/ laptop hd),
OR sollid state memory sticks that are as large as 32GIG USB2 (not cheap)
but reliable shockproof, and LOW power...
www.windowsmarketplace.com/details.aspx?view=info&itemid=2632063
It just depends on the amount of storage you need..
Here is a link to video capturedevice evaluations ect.
www.videoguys.com/vidcap.htm
Bob
The problem with it, is that it will not withstand the G-Forces encountered during the Baja race...
Your best bet is a small form factor mob with passive cooling, and solid state storage...
It will have a ethernet port as well, and is easier to configure softwarewise....
Your main cost will be RELIABLE storage....
A laptop HD just will not withstand the G-forces encountered reliably..
Flash drives will, and also use less power, and you can connect more than one drive to the mob
for increased storeage capacity...
You need to figure out how good of a quality you want to record video versus how much storage
you will have/get, and go from there...
Bob
Post Edited (Robert Kubichek) : 2/12/2007 8:25:09 PM GMT
Next compression codecs.· listed from worst compression ratio to best compression ratio.· Huffyuv(lossless), MJPG, MPEG-1, MPEG-2 (DVD's and HDTV), MPEG-4 (Divix, Xvid), H.264.·· RealVideo, MicrosoftVideo, and Quicktime all fall into this range but are non-standard and don't produce better results anyway.· The above list is also ranked in terms of computer horsepower needed.· With MJPG being the easiest, and H.264 being the hardest.· Infact I think only top of the line CPUs (or dedicated hardware) can do H.264 in realtime.· (personally i'd go with MPEG-4 Xvid if the system is fast enough)· Whatever compression codec is finally chosen, be SHURE to extensively test the compression and play with all the settings given.· Oh yea, going with 15fps video can save some space with MPEG compression but it's only like 10% and can make high-motion video look crappy.· (dropping the resolution gives similar small gains in compression so while it can help don't go wild)·
A bonus if you go with MPEG-2 compression is that a large number of TV-capture cards now do·MPEG-2 in hardware, this makes the overall system MUCH more stable and lets the CPU do other stuff (like play games!).· If you do decide to use a TV-capture card I'd recommend going with a Hauppauge product.· http://www.hauppauge.com/·My only reason for recommending a Hauppauge card is that they·seem to be supported by the most 3rd party Open-Source software packages.·
http://www.virtualdub.com/· VirtualDub is the program I primarily use to convert video files from one format to another.· It also has a superb video capture system builtin.· This system provides rock solid audio/video sync and will automatically split up the output file into managable chunks.· Although the capture system in VirtualDub is now out·of date thanks to microsoft.· ·(it was built in the Win98 days)
Finally, storage.· 5G shock isn't that harsh.· (I think hard drives are spec'ed to 10g or 20g operating shocks don't trust me though, read the data-sheets) ·I wouldn't be supprised if a well shockmounted RAID-5 array with a few hot-spares could survive the trip just fine.·(the heat would likely be the worst part of the trip)·WinXP pro· can do software RAID-5 arrays (ofc Linux can do this too) and big hard-drives are cheap now so this plan could allow 1-2Tbytes of data storage.·
http://www.avsforum.com/·is the best Web-forum I've found for video related info.· Lots of people on that forum will be up to date on this stuff.
My 2¢,
Marty Lawson
Anything can be shock-mounted against short-duration jolts. It's not like the G forces will be sustained, as they would be in a fighter jet. That aside, though, the bigger issue with the Buffalo unit is likely to be its fan cooling versus the Baja dust. Another solution, more along the lines you mention, is the LinkSys NSLU2 NAS unit. This is a diskless device with two USB 2.0 ports that could be used for flash memory sticks. But I'm wondering if flash memory has a fast enough write speed to accommodate real-time video. The Sony MemoryStick, for example, comes in two flavors: regular and Pro. Only the Pro version is fast enough to capture extended video using a Sony digicam. I doubt that most USB pen drives are up to that level of write performance.
little bit 2. CompactFlash type memory cards act exactly like ATA hard drives. (fully bootable, no need for OS support, just need a plug adaptor) I've seen some models quoted at 40MByte/s read/write speeds but this app won't need anywhere near that.
I don't think write speed will be an issue with Flash memory. 1Mbit/s MPEG-4 video looks dang sharp at TV resolutions and even cheap usb flash drives should be able to manage that speed.
another tidbit u might find usefull. My TV card has a hardware MPEG-2 encoder so it can record while i'm doing ANYTHING else. (CPU use is ~5% during recording, the only way i know it's recording is 'cause the HD light is constantly blinking) At 640x480 ~30fps with 32KHz compressed audio and a data rate of ~4.4Mbits/s total, compression artifacts are hardly visable (an "average" TV signal was the source, the stuff I could see was mostly from the source noise). That comes out to a little less than 2GBytes an hour or 80GBytes for 40 hours of video. At ~2.2Mbits/s with the same fram size, frame rate and a bit more audio compression video quality is still very high, compression artifacts are visable, but not a problem yet.
My 2¢,
Marty
At work we have a receiver (for RF) tucked in what is basically a beer fridge. Lots of heat in dat'der'box. So there's a copper fin plate in the lid that has fans on both sides (in and out) to move air across it.
A pelletier with the cool side touching the outside of a metal box will do alright. On the inside have a pc fan/sink moving air across the cool spot!
As far as g's....sustained G's wouldn't be near 5g's....but sometimes these things are rated on certain angles. A flat drop as opposed to a corner drop...
Anyhow, if anything comes loose it'll certainly generated more than 5g's.
Something shock mounted and dampened would work fine!
Steve
I will see what this guy wants to do, I at least have a few more ideas/options now that I can suggest the why vs. the why not.
Beau Schwabe
IC Layout Engineer
kelvin
PC104 might be an option. They are industrial, small and offer frame grabbers and memory storage.
Have you looked at M-Systems for storage?
http://www.m-systems.com/NR/rdonlyres/DF55B3A3-E128-4666-B894-48D48E031019/0/DOC2000_DIP_DS_Rev39.pdf%7CDOC_2000_DIP_DS_Rev3.8.pdf
Looks like they have a 1 gig solution.
PC104 frame grabber card here that looks like it might work.
http://www.sensoray.com/products/311data.htm
I like the idea of a Tivo and a video camera as well as having redundancy, but there is some harsh terrain that may limit the "amount" of heavy/bulky equipment
placed on the vehicle. For example there was a part of the race last year that had this guy going through a mud puddle waist deep. I have some experience
with shock-mounting and video stabilization using gyro-s (I once fit an ultra-light aircraft for some aerial photography), but due to the circumstances it becomes
a matter of how compact and weather proof the unit can be made. The Tivo would just need to be shock proofed, while the camera needs both shock and
image stability.
Beau Schwabe
IC Layout Engineer
Heh, just because the Tivo started out bulky doesn't mean it has to stay that way [noparse]:)[/noparse]. Stripped down to the electronics with a new powersupply, case, cooling, and front panel buttons I wouldn't be supprised if a pair of Tivo's could fit in less space than a single stock unit.
Marty
Bob
There are LOTS of DVRs out there -- I went poking around. Priced $150-$3000 depending on features, cameras, etc. Many offer over 40 hour record time.
Here's one I found on Ebay that records full DVR (Divx or MPEG4 compression, 30fps, 720x480) and it's portable -- which means small and probably a bit durable:
cgi.ebay.com/ARCHOS-AV500-30GB-MULTIMEDIA-PLAYER-DVR-4-IN-LCD-SCREEN_W0QQitemZ130079926469QQihZ003QQcategoryZ48682QQrdZ1QQcmdZViewItem
This bidding ends in an hour, so not sure it will still be there if you go look
electronics.search.ebay.com/dvr_Consumer-Electronics_W0QQfkrZ1QQfromZR8QQsacatZ293QQsubmitsearchZSearch
Consider having a quick peeky boo here.Two links below
http://www.helmetcamera.com/
http://www.helmetcamera.com.au/home.htm
A std video camera or a device like a Trivio( and others ) do a pretty good job
A guy I know has a Helmetcam .. he is a crack rider .. mono's up steep hills and on extremely
roug and rocky terrain .. we go for hours and hours .. uses tapes and a few small batteries.
Ronald Nollet·· OZ··
"I think that aside from engine/drive vibration a car's chassis is pretty stable."
Thanks, your right something secured to the car might not be as thrown around as the driver would be.
Zoot,
"Tivos use a phone line/broadband to communicate with Tivo central -- to what end, I don't know"
Hmmm... surly there is a way to defeat this... what if you are a customer in a remote area without phone
service and you want to Tivo something off of satellite. (Obviously I am behind the times and don't have
a Tivo box)
Wow, The DVR "Really" looks like the way to go.
The ARCHOS AV500 30GB MULTIMEDIA PLAYER has an impressive boast under its Product Features:
"Plays and stores up to 400 hours of video, 250 movies, 55,000 songs or 1,000,000 photos"
Looks like this is a regular E-Bay Item ... Right now, there is one going for under $100
Beau Schwabe
IC Layout Engineer
In any case, as you've seen, there are lots of plain DVRs out there that are not much different than a regular old time VCR.
Those helmet cams are cool -- their recorders look limited to 4 hours or so, though. The idea of recording to SD cards rather than a hard drive is neat, though.
Equipped with his 5 senses, man explores the world around and calls his adventure science
-Edwin Hubble
I have not seen any units that don't require a subscription to some service, so I can't comment on how they work.
Truly Understand the Fundamentals and the Path will be so much easier...
