Programing a BS2 using a zire71 Via serial port
Hello,
I would like to start of this post with a thank you in advance.
I own a zire 71 and would like to program my Bots anywhere. I own a USB sync cable and a SERIAL sync cable and would like to know if it is possible to create pbasic code on my zire and then compile the data to my BS2?
If your "Zire" is Windows or Linux compatible, the answer is probably yes. If not, the answer is probably no.
What is a "Zire".
Bruce Bates
<!--StartFragment -->
- Stephen
a Zire 71 is a Palm OS PDA.
John R.
Click here to see my Nomad Build Log
There's a new DOS emulator for any Palm later than OS5, which you can find HERE: sourceforge.net/projects/palmdosbox
It's new and buggy, but it might-- just --MIGHT run Stamp2.exe available HERE: www.warburtech.com/basic.stamps/basic.stamp.bs2-ic/
(It might still be available on the Parallax website, but I haven't found it)
It won't allow you to use the new 2.5 command set, but it's a start.
It's actually been on my list of to-do items to see if it would work, but that list is longer than my arm and growing.
So-- give it a shot and tell us how it goes.
I have downloaded the dos box and it is incompatible with my pda, I get a error on my pda saying..."hold on i need to get my pda" Cant Load Module. I will try to contact the developer of dos box and see if i can get some assistance. Ill come back with a response once I obtain one.
These are DOS-based and with a keyboard and serial ports.
(I used one myself, to program my BS2p24)
You may have the software hang now and then after uploading to a BS2, particularly if you use the DEBUG screen, but that clears up after a minuter or five(Just enough time to make a nice cup of tea, in my experience) as the serial port interface may not be completely compatible...
Just one warning, these machines, particularly those with the most RAM tends to be pricey on eBay as they are still popular with sailors, who use them to decode 'weatherfaxes'.
A friend has a picture of one, and a description of how he used it on his pages, unfortunately, his boat was hit by a large cargo-ship in the atlantic and he lost his HP, his Psion and just about everything else.
Don't visit my new website...
Research into what is needed for programming and what the Zire can provide is probably in order.
Truly Understand the Fundamentals and the Path will be so much easier...
If I could obtain that info, I could recreate a program that works almost like the original version.
There is no complier for PBASIC per se, as it's an interpreted language. There is an Editor/IDE and the proprietary firmware, that's it in a nutshell.
Bruce Bates
