This is my solder station foam flip board — Parallax Forums
metron9metron9 Posts: 1,100
edited 2007-02-09 07:08 in General Discussion
It works great I can solder up a dozen boards in about 2 hours.
The panels are 42 up and they all snap apart.
I load the parts and it just flips over, the foam holds the through hole parts in place while soldering.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
  • aalegadoaalegado Posts: 66
    edited 2007-02-04 18:38
    That's cool. Is that a Luxeon LED near the top-center of each board?
    I wouldn't connect that if I were you...
    Vive Le Tour!
    Le Grand Depart July 6-8, 2007
  • metron9metron9 Posts: 1,100
    edited 2007-02-04 19:59
    Yes, the 1 watt emitter. From the back you can see the hole in the board. I then use a piece of adhesive foam with a 1/4 inch hole in it, I fill that hole with T-putty 504 thermal putty and stick it to the aluminum body. These lights don't get very hot as they are not driven 100% duty cycle but the thermal design will take 100% duty cycle at 350mA just for a safety margin.
  • boeboyboeboy Posts: 301
    edited 2007-02-04 23:28
    where did you get it?
    lets see what this does... KA BOOM (note to self do not cross red and black)
    Sorry for the delay, I bought it here
    http://www.mainelectronics.com/PCBRDHolder.htm
    So much to do and so little time...
