Assembly Doesn't Work Right — Parallax Forums
JamesxJamesx Posts: 132
edited 2007-02-09 01:43 in Propeller 1
I have a simple problem in assembly that is bugging me. Please refer to the program below, which is set up for a Demo Board Basically, I set up a CLK pulse to run really slowly, and flashes an LED. Another part of the program monitors that pin and once it goes high a second LED is flashed on/off. This happens 5 times, the second LED stops flashing, and the program then goes into an infinite loop.
The problem is with the MOV t1, #0 statement at the top of the program. If this statement is included, the counter T22 does not get incremented properly, and the second LED keeps flashing. Only if this statement is commented out does the program work as expected.
Why does it work this way? It shouldn't make any difference whether or not this MOV statement is included or not.
I have tried with an ADD t1, #0 statement, and when an ADD is used instead of a MOV, the program works as expected and stops after 5 times through. What difference would it make if an ADD statement were used instead of a MOV?
For those interested in following along with a Debug mode, there is a 230400 baud output on Pin 6. The code for this is derived from the Fullduplex object.
Thanks for any ideas.
Jim C
CON
  _clkmode      = xtal1 + pll16x                        ' use crystal x 16
  _xinfreq      = 5_000_000                            ' external xtal is 5 MHz
PUB start
  cognew(@entry,0)
DAT        org
entry       or        dira,   PortBits
     '        mov       t22,    #0
              movi      ctra,#%0_00100_000      'set counter mode to NCO single ended
              movs      ctra,#%00010000         'set  APIN to portbit 16:  CLK
              mov       frqa, Freq_                        '
              or        outa,   txmask
Main_Loop     test      CLK, ina     wz
     if_nz   jmp       Main_Loop
               or        outa,   LED             ' LED on to track progress
               mov       Time,   cnt
               add       Time,   delay            ' pause: to after CLK
               waitcnt   Time,   #0
               andn      outa,   LED             'LED off
               mov       txdata,t22
               call      #transmit
               add       t22,     #1
               cmp       t22,    #5     wc
     if_c     jmp       #Main_Loop
test_5       nop
                jmp       #test_5
transmit
                or      txdata,   #$100
                shl     txdata,   #1
                mov     txbits,   #10
                mov     txcnt,    cnt
:bit           test    txdata,   #1       wc      ' output bit
                muxc    outa,     txmask
                add     txcnt,    bitticks         ' ready next cnt
:wait         mov     t4,       txcnt            ' check if bit transmit period done
                sub     t4,       cnt
                cmps    t4,       #0           wc
    if_nc     jmp     #:wait
                shr     txdata,#1
                djnz    txbits,#:bit               ' another bit to transmit?
transmit_ret  ret                                ' jump to instr. after call instr.
t22            long      0
Delay         long      30_000_000
CLK           long      %00000000_00000001_00000000_00000000
PortBits      long      %00000000_00000011_00000000_01000000
LED           long      %00000000_00000010_00000000_00000000
Freq_         long      %00000000_00000000_00000000_10000000
bitticks      long      348                                   'for 230400.baud
txmask      long      %00000000_00000000_00000000_01000000
Time         res       1
t4             res       1
txdata       res       1
txbits        res       1
txcnt         res       1
    edited 2007-02-08 20:31
    Isn't this the same problem you were reporting in this thread: http://forums.parallax.com/showthread.php?p=630422
    Is there a reason why·you are starting a new thread?
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 2/8/2007 8:45:33 PM GMT
  • JamesxJamesx Posts: 132
    edited 2007-02-08 21:52
    Same problem. Same obsession. Sorry for the second thread. Can we remove the first one?
    Jim C
    edited 2007-02-08 22:47
    The problem is that you forgot to put a # on the 'if_nz jmp {#}Main_Loop', which was causing it to jump to the contents of the Main_Loop location's lower 9 bits, not·to Main_Loop. So, it was jumping to INA ($1F2), which would read an instruction like a D (not an S) register,·causing a·$0000_0000, or NOP, to execute. It was then executing NOP's all the way $1FF,·at which point·it wrapped around to $000 and executed your program from the beginning, hitting that 'mov t22,#0' at $001 again. Forgetting the # on a jmp can cause crazy things to happen.
    Jamesx said...
    CON
    PUB start
      cognew(@entry,0)
    DAT        org
         '        mov       t22,    #0
                  mov       frqa, Freq_                        '
                  or        outa,   txmask
         if_nz   jmp       Main_Loop
                   mov       Time,   cnt
                   waitcnt   Time,   #0
                   mov       txdata,t22
                   call      #transmit
                   add       t22,     #1
                   cmp       t22,    #5     wc
         if_c     jmp       #Main_Loop
    test_5       nop
                    jmp       #test_5
    transmit
                    or      txdata,   #$100
                    shl     txdata,   #1
                    mov     txbits,   #10
                    mov     txcnt,    cnt
                    muxc    outa,     txmask
                    sub     t4,       cnt
                    cmps    t4,       #0           wc
        if_nc     jmp     #:wait
                    shr     txdata,#1
    t22            long      0
    Time         res       1
    t4             res       1
    txdata       res       1
    txbits        res       1
    txcnt         res       1
    Chip Gracey
    Chip:
    Thanks for the explanation of my simple error. I figured it was going to be obvious once it was pointed out: I just couldn't see the tree for the forest.
    This also explains why it worked correctly with an ADD #0 instead of the MOV #0. Returning to the ADD instruction, while incorrect as the flow was intended, didn't alter the incremented variable. But, returning to the MOV #0 each time zero'ed out the variable each time. Duh!
    Jim C
