Ideas, Ideas, Ideas!
Got a new one, and I am loving this one. So, I was sitting here thinking, and tell me what you think of this idea, mounting my small web cam on a servo motor, and using the Basic stamp to control the servo, but, thats not all, how about putting a motion sensor on the front of the cam. The program would make it so that the motion sensor move towards the direction that the motion came from (possible or does it just track motion and not direction) so that the cam follows me, that way, when I am talking to someone with my cam, even if i move my head, the cam will follow to keep me centered in the shot. Possible?
I've seen things like this before where the person wears an infrared transmitter (in a lapel or hat or something) and the camera has sensors that can track where the IR is coming from (IR sensors with tubes to make them directional).
It would be a cool project.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
I'm not sure ultra-sound would keep you 'centered', exactly, but the 'beam' is probably narrow enough to keep you in-frame.
http://forums.parallax.com/showthread.php?p=611413
So here's my suggestion based off what is discussed above - use IR and wear a reflective hat or something like that so that the IR can pick you up easier. Adapte·the code Parallax wrote from sonar to IR - it would be realatively simple.
Then·mount the camera directly above the IR unit·so that as your hat reflects back the light the camera and IR turn on the servo to follow you.
Bean.
