Internet Enabled Force-Feedback 'Rod'
Hey Everyone! Ive got a project... I need some advice on the mechanical side. Check out this illustration:
So. I am a bit stuck. Any ideas on how to make this thing feel like it would if you and a friend were fighting over a broomstick constrained to 1 axis of movement?
3D & 2D Design - Technical Documentation
www.robertguyser.com
- Stephen
heh, this could be as easy as using the raw encoder position of system A as the position goal command for system B, while at the same time using the raw encoder position of system B as the position command of system A. (assuming a simple PID servol loop is used in each system A and
Is this going to be internet enabled? Tug-O-War from different time-zones!
my 2 cents
Yes. I want it to be internet enabled 'tug of war' . really this is research towards a larger goal, but i have simplified this larger goal into something easier to attain.the reason i am asking for help before building any test apparatus is that the timing cogs and belt, shaft couplers, etc. are very expensive, especially when building 2 identical devices.
Your second paragraph outlines my initial conception of the project.. Device A's encoder directly updates the position of device B, and vice-versa. In addition, the current being consumed by the motors would be used to simulate force... The hard parts are many... feedback loops seem like a real problem... if device A tells device B to move just a little bit, and it overshoots....
Grrr. this is hard, but I REALLY want to make it work.. Unfortunately I am possibly not smart enough.. I like to make pretty things..
my first thought for the tug of war version involved a reel, a rope, a stepper motor, a spring loaded 'pneumatic tube', and a linear encoder... see...
www.robertguyser.com/tug.jpg.
In the near future I will hook up a small servo with encoder and a sense resistor circuit... To start....
I am amazed noone else has done this project yet - internet tug of war.. i think its just soo cute.
Interesting concept!
In order to do this, the "heart" of the device would consist of a strain-gauge at each end. BOTH values from the strain gauges should be equal or constantly strive to be equal.· With that said,·the only information that needs to be communicated is the·value of the strain-guage.· Each side would consist of a closed loop with reference to the strain-gauge values. What ever method you choose, a linear actuator, rope on a reel, etc. The idea would be to "match" the value from the strain gauge to the counter force of the actuator. Set limits in software, so that there needs to be a certain threshold on the strain-gauge before anything happens. This level should be set only slightly above any noise floor obtained from the sensors, so that at rest, everything is stable.
Pseudo code(one side)
1) Read Strain-gauge from remote side in the form of a data transmission
2) Read Strain-gauge on·local side ; send information to remote side in the form of a data transmission
3) If Strain-gauge from #1 is greater than Strain-gauge from #2 (add threshold) then increase pull on local actuator.
4) If Strain-gauge from #1 is less than Strain-gauge from #2 (subtract threshold) then decrease pull on local actuator.
5) repeat steps 1 through 5
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 2/9/2007 6:13:59 AM GMT
Thanks for the suggestions.. i am uploading this really half-assed worksheet i was using.. i sorta solve problems visually. and cuz i know i need help, i am doing it digitally for this project.. anyhow.. i think that both of you bring up good points... also worth mentioning, i am not going to build a giant machine that needs to be anchored to the foundation or whatever a real tug of war machine would require... its going to be for 2 fingers, pretty much.. i am working towards a different device.... which i do not know the term for.. but it is a grid of pins that you can push and make shapes.. i want to make an internet enabled one... yes. i know.. importantly, i want it to be forcefeedback both ways.. i dont know what else.. but... i am doing tug o war first!
as you can see i stopped abruptly.. quitting time at work (hehe). and i somehow forgot the file at work. so i have to start a new one..
but to explain what is here.. i think i have identified 4 states to make routines for:
1. no action
2. team a pulling only
3. team b pulling only
4 both teams pulling
hardware (from the ol' 'inventory'):
-DC servo with motor with 64CPR encoder (from largish inkjet)
-section of linear encoder strip and optic sensor from a inkjet (dont know how many CPI yet, but its alot.. like 256)
-simple damper device... whatever is most linear i can find.. also considering a spring scale with a 10lb limit or something)
-thk linear slides - overkill!
-Hip4801 & mosfet H-Bridge
-Current Sense resistor and A/D convertor
-1 or 2 BS2s per device
i am working on trying to make pseudo-code loops to take care of each part.. the vb stuff is pretty easy for me, and the BS stuff is getting easier...
so.. i will post a new sheet soon.. hopefully some more interesting suggestions will come in as i create it..
thank you!
robert
Post Edited (RGuyser) : 2/10/2007 7:59:53 AM GMT
these particular slides are brand new thks... 12" long, 4 rails, 4 blocks.. $30 for all of it. oh, i love ebay.
in the meantime, i am late for work!
Meanwhile, if I happen across it, I'll let you know.
PAR
SORRY FOR ALL CAP. GOOFY PDA WONT TPE LOWEERCASE ALL OF A SUDDEN!
Interesting idea.
I like your solid modeling. Was that done in Pro-E? Ive been using Solidworks and It dosent look as cartoonish (not a bad thing)·as what you have. I like what you have, especially for a concept grawing.·Just wondering.
Google them to see how they work...but a summary would be....the action at one end gives an indicator at another.
Our Radars use them....as do our wind direction systems.
You have a synchro motor with 3windings (marked Stator 1, 2, 3) and a reference winding (marked R1,2). You put a reference voltage on R1/2 and connect a couple of these synchro resolvers up. In the case of a wind system, as the wind pushes the wind vane around, it changes the induced voltage on the stator. With the resolver connecting in parallel, you can connect a little arrow that will rotate with the wind vane from a remote location.
Ok, these may or may not work for you....but to get things working across a network, you could use a synchro to digital converter, and send the packets along to a "digital>synchro converter" that'll put the action on that end.
(being very vague and general with this as you have to find how to incorporate rotational directions in to your design...if applicable!)
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
