Basic Compiler or Basic to Assembly Translator
So far we have fairly slow, high-level, Spin interpreter and a faster, but more tedious to program with, assembler.
Is there any chance that a compiled basic (no interpreter) or basic to assembly translator projects might take off soon ?
I would like to see a very easy and efficient to use language like Basic without the OO stuff.
What is a chance that the project could get going through open-source ?
Any thoughts ?
Any thoughts ?
Note that Cliff Biffle has a partial Forth system for the Propeller
Also note that Spin is actually quite fast. You can do 19200 Baud serial I/O completely in Spin "bit-banging".
I'm working torwards a on chip assembler, first I have to get hydra's basic working ,there is a bunch of stuff in there that will come in handy in a assembler , there are some memory problems to address(like Mike noted) but I'm hoping that the new asset managment software will help me out.
Brian
There is a discussion floating on the forum about wheather it would make more sense to add more cogs or more program memory.
Why not have two versions of the chip, one with bunch of cogs and smaller memories and other one with less cogs and larger memory ?
Dropping 512 blocks into cogs from main memory with maybe another cog fetching blocks from SD card or external SRAM.
Interesting possiblities, use one cog as smart MMU, intelligent DMA? The OO stuff could be interesting, nice way to package the 512 blocks.
Some way to manage everyones objects could come in real handy, my prop folder is a mess, lose track of versions of Mike's and Rokicki's code.
Gavin
Alex2: I don't work for Parallax, so my thoughts arent' official nor do I have real numbers.. But I do know some things about electronic design/µP architechtures..
The memory, that will be added is the Hub-memory (32KB to 128KB), not memory inside cog... cog-memory is more difficult to add, cause there are no free Bits in instruction word for accessing more than 512 Longs of local memory.
For making two new chips?... Heck.. even making one costs hundreds of thousands USD (at least, may well be more) , with all prototypes, asic testing and requires many man-years of work. Asking them to do many different architectures is quite a lot..
Post Edited (JoannaK) : 2/5/2007 4:13:41 PM GMT
Bill's basic idea was that you could read an instruction from Hub RAM into Cog RAM slightly more than every 3 instructions on average and execute it inline. All the operands would have to be in the Cog which is usually not an issue. The jump instructions would have to be handled specially since you're really using the address pointer to Hub RAM as the program counter. Essentially you have:
:loop rdlong :next1,pc add pc,#4 :next1 nop jmp #:loopalthough he "unrolled" this loop a couple of times (duplicated the code so there was a jump for every 4 "cycles"). That's one instruction about every 160ns. Still pretty fast. He also added multithreading and you could have a real stack if you want (with the stack in Cog RAM if you want) since jump type instructions are implemented as subroutine calls to routines in the Cog through a jump table. Read the threads on this.
Well not quite, been reading the manual and Andre's book at night and getting into the assembly instructions.
Bit hard to extend the instruction address range when limited to 9 bits, nearly ready to go back and look at Bill's code.
Starting to get excited about learning assembly for the first time in ages, I'm normally a hard core C guy but to get the most from this thing I am going to need assembly.
Discovering lots on holes and yet to be explained things in the manual, lots still to discover but they are still simple cogs.
An apnote on the Vid gen would help especially VGA, I keep on thinking up other uses for them that I don't know enough about that section to know if it will work. Compared to some micros a single cog is looking very simple, next stage is to figure out how they are connected. Probably should spend some more time pulling apart the assembly objects for more clues
Gavin
Paul Baker
Yep figured it was on the list somewhere, 3rd is fine.
Andre does a good job for NTSC TV not so much info on VGA or PAL.
I really need to get into the assembly code, still only dabbling in spin.
I keep on thinking about using the vid gen as a high speed 8 bit output pattern generator.
Sticking byte patterns in ram and it spiting them out as PWM high freq 8 channels at once.
6 is all I need for PWM BLDC motors, but just don't know enough about the vid gen.
Changing the vid clock rate should change the motor speed. The high speed should allow for PWM sin wave drive.
Could even tweak the ram data for pseudo spread spectrum sin wave.
May not even need to learn assembly to do it?
Still reading between the line on the vid gen, hence hanging out for the ap note.
Gavin
Paul Baker
