Hall effect sensors
stev0tron
Hey all, I'm pretty much a beginner in the field of robotics and am looking for a decent sensor to detect a magnetic field of about 10K Gauss. Anyone know of a company who manufactures a reliable sensor with a fairly long range?
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
Well then the magnetic field that you measure would not still be 10KGauss at the measurement point, would it? Magnetic field strength cannot be measured from a distance directly, the same as you can use an IR sensor to measure the surface temperature of an object a few feet away. You can only measure the magnetic field where the sensor is. The field is directional too. It's similar to trying to directly weigh a pile of sand with your scale covered by the sand at the edge of the pile. It don't work.
Perhaps if you instead state what you are trying to accomplish, somebody can help point you in the correct direction.
Also, do a bit more reading about magnetism before you proceed. It's interesting stuff.
Rick
The current/voltage of a coil will change with the changing gaussian field.
Thats how metal locators work by measuring the changes of earths magnetic field when a piece of metal is near.
Each type of metal has it's own characteistic way of changing earths magnetic field..
Bob
