Dot_matrix_display
i try to program a dot matrix display
i want some text like my name to display one by one
the first letter i have is an p and than i want an e ext..
the problem that i found is i can not make the letters display so you can read it
if you want to display a word
have anyone already try this
so they can help me out with this
thanks
greetings me
thanks
greetings me
I've done what you are trying to do. Check out my source code: http://forums.parallax.com/showthread.php?p=630082 and schematic: www.parallax.com/dl/docs/prod/boards/ParallaxPDB.PDF. Please answer my question in the same link as my source code in the first of 2 posted URLs here.
Lilly.
Pics;
Post Edited (latigerlilly) : 2/5/2007 3:55:51 PM GMT
Let me know if you need any help on anything I have provided. I have spent a large amount of time researching this type of stuff over the last couple of years.
Tim
give me more
I am from HOLLAND!!!!!
sorry for my bad english [noparse];)[/noparse]
well i need to know how i can easy program a dot matrix (stand alone)
i already have some letters but if you can see in the picture the letter s is realy bad
and if you can see the letter s of T&E Engineer·is very good
so i try to find a solution to make him as good as T&E Engineer·mayby the problem is that i got a dot led matrix of (ledtech (type) lj2041-21-s02)
and to make letters is also very difficult because i dont have a register
on my school the say you need to make a form like
0000
0001
0010 etc and than you can make it in hex
so i hope someone already have made something like i want to make
and than the next thing i want is to control 7 dot led·matrix's
but first one
greetings me
Post Edited (TheBest) : 2/5/2007 7:34:27 PM GMT
Tim,
·· OT for a moment here...I'm not sure why you've had any difficulty in daisy chaining the MAX7219.· It should be pretty straight forward.· While I have never had the need for more than 8 digits, I have read up in the data sheet and it would seem these work very similar to the 74HC595 in that you would need to shift all the data down the line and then activate the CS lines for the appropriate units.
Chris Savage
Parallax Tech Support
first stage is there
no more leds burning how i dont want to burn its a nice s or 5
·It looks good now.
there are 5 cols
and if you program the first col like this
(oke this look very basic but it works and i have to modify it more )
LOW 12
HIGH 2
HIGH 3
HIGH 10
HIGH 9
HIGH 5
HIGH 8
HIGH 13
HIGH 7
HIGH 4
HIGH 11
LOW 0
LOW 6
HIGH 1
PAUSE 1
than the first col blinks up but because the outputs will hang (it look like that ) i send te next string for the same col
like this
HIGH 12
HIGH 2
HIGH 3
HIGH 10
HIGH 9
HIGH 5
HIGH 8
LOW 13
LOW 7
HIGH 4
HIGH 11
LOW 0
LOW 6
HIGH 1
PAUSE 1
everything go off and you dont have a blur on the other leds more know you can go on with the other cols
mayby it looks like nothing but it works
But i am not finisch
http://home.wanadoo.nl/electro1/avr/dotmatrix.htm
There are several pages of related projects so besure to click on the top "NEXT" button to move forward.
This page should help you to understand how the display is generated.
Also this link (below) is what I used for my BS2 scrolling display sign.
http://drew.hickmans.net/movingsign.htm
I hope this gets you going. It took me a while after reading and re-reading over and over again.
Tim
i got all the letters i want.
but how can i program that first the letter a and than the letter b ,c,d,e,f, etc appear
so i want to show first letter a and after a while letter b
but i dont know how
anyone an idea
greetings me
Post Edited (TheBest) : 2/7/2007 9:18:53 PM GMT
PS: I have not tried this yet but it should provide the correct idea for you.
' {$STAMP BS2}
' {$PBASIC 2.5}
Letter· VAR Byte
Main:
DEBUG CLS, "Enter a Letter: "
DEBUGIN Letter
IF Letter = "A" THEN LetterA
IF Letter = "B" THEN LetterB
GOTO Main
LetterA:
' You can figure out the correct statements for an A
·LOW 12
·HIGH 2
·HIGH 3
·HIGH 10
·HIGH 9
·HIGH 5
·HIGH 8
·HIGH 13
·HIGH 7
·HIGH 4
·HIGH 11
·LOW 0
·LOW 6
·HIGH 1
·PAUSE 1
·HIGH 12
·HIGH 2
·HIGH 3
·HIGH 10
·HIGH 9
·HIGH 5
·HIGH 8
·LOW 13
·LOW 7
·HIGH 4
·HIGH 11
·LOW 0
·LOW 6
·HIGH 1
·PAUSE 1
Return
LetterB:
·'You can figure out the correct statements for a B
·LOW 12
·HIGH 2
·HIGH 3
·HIGH 10
·HIGH 9
·HIGH 5
·HIGH 8
·HIGH 13
·HIGH 7
·HIGH 4
·HIGH 11
·LOW 0
·LOW 6
·HIGH 1
·PAUSE 1
·HIGH 12
·HIGH 2
·HIGH 3
·HIGH 10
·HIGH 9
·HIGH 5
·HIGH 8
·LOW 13
·LOW 7
·HIGH 4
·HIGH 11
·LOW 0
·LOW 6
·HIGH 1
·PAUSE 1
Return
how can i program him that he show for 5 second an a and after that 5 seconds an b
greetings me
now i have this
' {$STAMP BS2}
' {$PBASIC 2.5}
Letter· VAR Byte
Main:
DEBUGIN Letter
IF Letter = "a" THEN LetterA
IF Letter = "b" THEN LetterB
GOTO Main
letterA :
LOW 12
HIGH 13
HIGH 7
HIGH 11
HIGH 0
HIGH 6
LOW 1
PAUSE 1
HIGH 12
LOW 13
LOW 7
LOW 11
LOW 0
LOW 6
PAUSE· 1
LOW 2
LOW 3
LOW 9
HIGH 8
HIGH 1
PAUSE 1
HIGH 2
HIGH 3
HIGH 9
LOW 8
LOW 1
PAUSE 1
LOW 5
HIGH 13
HIGH 7
HIGH 11
HIGH 0
HIGH 6
LOW 1
PAUSE 1
HIGH 5
RETURN
letterB :
LOW 12
HIGH 2
HIGH 3
HIGH 10
HIGH 9
HIGH 5
HIGH 8
HIGH 13
HIGH 7
HIGH 4
HIGH 11
HIGH 0
HIGH 6
HIGH 1
PAUSE 1
HIGH 12
HIGH 2
HIGH 3
HIGH 10
HIGH 9
HIGH 5
LOW 8
LOW 13
LOW 7
LOW 4
LOW 11
LOW 0
LOW 6
LOW 1
PAUSE 1
HIGH 12
LOW 2
HIGH 3
HIGH 10
HIGH 9
HIGH 5
HIGH 8
LOW 13
LOW 7
HIGH 4
HIGH 11
LOW 0
LOW 6
HIGH 1
PAUSE 1
HIGH 12
HIGH 2
LOW 3
LOW 10
HIGH 9
HIGH 5
HIGH 8
LOW 13
LOW 7
HIGH 4
HIGH 11
LOW 0
LOW 6
HIGH 1
PAUSE 1
HIGH 12
HIGH 2
HIGH 3
HIGH 10
LOW 9
HIGH 5
HIGH 8
LOW 13
LOW 7
HIGH 4
HIGH 11
LOW 0
LOW 6
HIGH 1
PAUSE 1
HIGH 12
HIGH 2
HIGH 3
HIGH 10
HIGH 9
HIGH 5
LOW 8
LOW 13
LOW 7
LOW 4
LOW 11
LOW 0
LOW 6
LOW 1
PAUSE 1
HIGH 12
HIGH 2
HIGH 3
HIGH 10
HIGH 9
LOW 5
LOW 8
HIGH 13
HIGH 7
HIGH 4
HIGH 11
HIGH 0
HIGH 6
LOW 1
PAUSE 1
RETURN
Post Edited (TheBest) : 2/8/2007 6:01:45 PM GMT
I did not have my computer with the BASIC Stamp Editor software and HELP files when I answered before. You need to use a PAUSE statement not DELAY.
For example if you wanted your program to Pause for·3 seconds then you would enter a command such as:
PAUSE 3000
where 3000 represents 3000 milliseconds which is the same as·3 seconds.
Just put the PAUSE statement before your RETURN statement this way it will pause and keep on the LEDs until it returns back to input the next character.
I have not tried this and YOU need to try this and experiment a little for the correct placement.
You should also go through the HELP file on the BASIC Stamp Editor program.
