Just received 2 HB-25s and need motors/wheels suggestions
My project is to replicate my boebot on a larger scale. Currently, on my boebot, I have the ping module and IR working like a champ and my software works well in autonomous mode. Based on this success, I want to make a bigger bot using the same programming and sensor techniques. The HB-25 seemed to be a good starting place.
My question: Which motors and wheels are recommended?· I want to use 12V only, two motors controlled independently by two HB-25s, wheels 6 in dia or more and speed close to human walking speed. I will use a free pivot wheel in the back of the bot in boebot or R2D2 style. Direct drive will be used - no chains or sprockets (that will be a future project).
My problem: Lots of suitable motors are advertised but I also need mounting brackets and wheels that would mount on whatever motor. I don't have a machine shop at my disposal. I want to purchase a pair of motors and parts·to mount·on a chassis·and attach the large 6 in wheels.·
Any suggestions would be appreciated.
Try taking a look at this site: www.robotmarketplace.com/marketplace_motors.html. You will probably want to shop around, but at least this will give you a start on what kinds of motors are avaialable. The page I linked to is the "motors" page, but that same site also has wheels, tires and hubs to go with the motors.
To get a feel for the speed, use this formula:
Motor RPM * Wheel(Tire) Dia in inches * Pi = Inches per MinuteOnce you have a few motors that get you the speed with an appropriate tire size, then you can look at voltage, torque and cost to make a choice.
John R.
Link to My Nomad Build Log
Using the formula supplied by John R. and using a nominal 85 RPM (12 V @ 10 A): 85 RPM * 8 in * 3.14 = 2135 in/min = 35.6 in/sec Acceptable speed.
Am I headed in the right direction?
Thanks for the replies.
LR
John R.
Click here to see my Nomad Build Log
