PA equipment help
This doesn't have anything to do with Parallax products but this is the sandbox and between any 3.1416 of you guys all knowledge is known.... My problem is week after next I will be part of a small group who will be teaching a class on concrete mix design. We do this at a out of the way camp with a large assemble hall where we give the presentations before breaking into workshops. For several years we have used PowerPoint with an LCD projector for the presentation part while also using a number of videos connected to 4 TV's located around the hall. (We have 80-100 people in attendance) Last year we found it was quite a bit better to feed the video from the VCR into the LCD projector and display it on the big screen. That worked fine. The problem was audio. When we tried to feed the audio from either the VCR or the laptop's sound card into the PA system, either the volume had to be turned down too low or there was irritating distortion. This year we won't be using a VCR, we have all the videos on DVD, but we need to hook the output of the sound card into the PA and run the volume at an acceptable level without distortion. Is there some 'magic' impendance matcher or preamp or what is needed? Thanks - Don
If it isn't for this check if te outputs are simple (RCA level) and not a amplifier output...
That's all from me...
I'm out...
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
kelvin
Just output enough to get a good low distortion signal...
Bob
