DMX transmitter possible?
Hi,
I have a fairly simple but specialized project. I am looking at BASIC Stamp 2 because of the
easy learning curve (I already have lots of programming experience, just not for microprocessors).
What I need to do is take a potentiometer style input, translate it into a value (either % of 100 or
0 - 255) and based on that, manipulate four DMX channels (which correspond to red/green/blue/white LEDS).
The DMX lights are preexisting. The relationship between POT input and color output is not at all linear,
which is why I have to program a microprocessor.
What I need to know is, using BASIC Stamp 2, is it possible to make a DMX transmitter that can control
four channels? (No DMX input, only output). For info on the DMX standard, look here: http://www.dmx512-online.com/packt.html
Assuming I have the components can I do this with a BS2 or must I use an external DMX controller?
Thanks a lot!
Thanks a lot!
- Stephen
The SX says its for developers with previous BS2 experience, is that something I should be worried about?
The code has very little I/O, but a fair amount of calculations to do.
What do you think?
Post Edited (rapscaLLion) : 1/29/2007 2:34:39 AM GMT
Chris Savage
Parallax Tech Support
So BS2 is out entirely? Even the BS2SX?
The reason I am scared to go propeller is I have no previous micro programming experience. Programming experience yes, but not at this level. Looking at all the BS2 stuff, I figure I could get a good grasp of it in 2 weeks before starting on the DMX project. Do you think a similar result is possible with the Propeller? (I know that's an unfair question)
Thanks!
But if there is already a DMX object for the propeller, that would probably be easier (although more expensive).
I assume the pot will control the hue, and the micro will convert hue to R-G-B ? That should be do-able on either micro.
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
I don't know what you guys mean by "SX"
I am asking about BS2SX-IC
Are you referring to that or to the seperate "SX" chip line?
We're talking about the seperate SX line.
If DMX is just serial you can just use SEROUT with the SX/B compiler for the SX line. (Even at 250KBaud).
Bean.
http://www.parallax.com/sx/index.asp
Chris Savage
Just out of curiousity, how many channels do you need to accommodate? If fewer than 512, are they all at low addresses?
You would also need an RS485 daughterboard for the DMX interface. Such a board would be easy to proto when the Proto-DB (prototyping daughterboard) becomes available — soon — with a commercial RS485 board further down the road.
What is your time frame, BTW?
There is another approach, but it's a bit costly. There are all sorts of DMX Interface boards available. Here is one web site, just to take a look:
http://www.bpesolutions.com/dmxproduct.html
Bruce Bates
<!--StartFragment -->
I think I will go with a Propellor processor, the time frame is a few months so I should be able to get the hang of it (I hope)
Thanks for your help selecting the chip, I'm sure I'll have more questions when I get my hands on it!
