Audio Sampling
How much storage space do I need for, say 15 to 30 seconds of audio with the bare minimum sampling rate? I'm using a digital-> analog converter, running the output over to a BASIC stamp, and using an aproximation of the I2COUT / I2CIN functions. I basically want to record audio of a D/A converter, store it, and play it back through a A/D converter.
I'm thingking of using one of microchip.com's I2C compatible EEPROMs around the 256-1024 KB range, but I have no idea what kind of A/D converter to use.
Well... saying that the minimum Kbps of play able sound is 8... Meaning that you have to record about a KByte per second... (Not very sure about that but still....) You have to use a large memory and a very quick ADC and DAC to play it back... Perhaps too quick for a Stamp... I have never worked with the SX (here in Greece·they are too expensive and as long as they come only in rails it isn't worth a try unless I can free sample one or two which I don't consider able, anyway....) to tell you they're able to "behave", but they are·VERY fast·..... Winbond offers some solutions, but you don't interface the BS2 much....
Hope I helped...
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
The A/D converter I'm using has a resolution of 8 bits, meaning that every time it samples a signal it outputs 8 bits or 256 possible voltage states. So sampling at 25 times a second I would be writing 200 bits a second. This probably wouldn't be doable, right?
Post Edited (abcdefg) : 1/31/2007 2:31:41 PM GMT
Alot depends on how fast the controller and the A/D is.
For 8KHz audio you need to sample and store 1 sample every 125uSec.
Another problem is that EEPROMs need to about 5mSec (5000uSec) to write data. FRAM would be a better choice.
What you are trying to do is not easy. Alot of things must happen quickly to pull it off.
Bean.
Is the rate of 8000 samplings a second the minimum or is it what is used normally? I might just abandon this project but thanks for all the info.
You can use less, but the audio gets crappy if you go much below 8K.
I have used the SX with SX/B to do playback from an EEPROM.
That is much easier to do.
I used a regular EEPROM and a parallal 8 bit DAC.
As I remember I setup an interrupt to read the next byte from the EEPROM and put the value on the DAC.
Bean.
Is it speech that you're digitizing? Here's a paper that goes into what gets lost when you reduce the bandwidth of digitized speech -
http://www.polycom.com/common/pw_cmp_updateDocKeywords/0,1687,6388,00.pdf
A good way to try this out if you have a PC with a sound card is to plug a microphone in and use the Windows Sound Recorder to make some recordings at 8 kHz, 8 bits, mono, PCM format. Record some speech, save it to a file, then play it back. That will give you a sense of the quality of that digitization rate and the size of the resulting data file for some number of seconds of audio.
David
Bean.
