communication to ethernet
I am trying to use a BS2 to send I/O data through an ethernet port to a computer database.
I think I have the serial part of the communications figured out.
Is there an easy way to convert to Ethernet-or should I just use a port server card?
Any input is appreciated.
MD
M.D.
Post Edited (MichaelDeFalco) : 1/25/2007 2:11:40 AM GMT
MD
M.D.
- Stephen
How is your system set up right now? Is the BS2 connected via serial cable to a networked computer, or is it standalone?
Here is what we all need . . .
http://www.elexol.com/Images/EIO24_LARGE1.jpg
I have three of them. I have had e-exchanges with Elexol and told them they needed to produce a wireless version of the Ether I/O 24 module so one would not have to lug around a (stripped down?) access point on the robot. They thought that was a very good idea. But, no product has sprung from that "very good idea."
--Bill
You are what you write.
Harrison
I looked into the port server similar to elexol-still a possibility
My units are stand alone & monitor machine inputs-
The plan right now is to use the BS2 devices via wireless hubs.
I will look into PINK...
MD
M.D.
This looks like the ticket-I appreciate the direction.
I will keep you guys posted-If interested.
Mike D.
M.D.
