RF Wireless Serial link questions
Hello,
Just received the set of transmitter / receiver pair for serial communications. I'm concerned that they appear to be all the same frequency (there are no designators or IDs to indicate different frequencies), so the tx/rx pair on one end will interfere with each other. Just wanted to know if anyone had any experience with them.
I plan to use one pair at a PC, and the other pair at an MCU on my robot. The robot would have a tx/rx pair, and the PC would have a tx/rx pair. Ideally they would be running on two different frequencies.
I suppose I could disable the receiver while transmitting, so I wouldn't get echoed characters back, but on the side that is the PC, there is no easy way to do that.
Thanks for any feedback,
Randy
Randy
I presume there's a PBASIC Stamp in there somewhere. Presuming that's the case, PBASIC does not support full duplex communications. The only reason I can imagine for using two different frequencies would be to perform full duplex communications.
Bruce Bates
<!--StartFragment -->
The Atmel can easily disable the receiver while it's transmitting (there's a disable pin on the receiver), but the PC can't easily do this, because PCs obviously don't have handy little I/O pins to do this kind of thing.
So the only real problem is on the PC side, I guess I just have to add code to receive and ignore the echo characters of everything I send.
I was hoping that since these units were sold as a set of four just for this purpose, that I could plug them into an existing control system without having to customize the logic on both sides.
Anybody have experience with these units? It seems like there is very little info from people who have actually used them, but they must have sold more that one set of them!
Randy
Its quite common in half-duplex systems for there to be one master broadcasting to everyone who can hear, but including an ID character in the string so only one listener will reply. Thats why many wireless devices come as transceivers which have the transmitter and receiver integrated into one package with an easy way to go from listen to talk. With separate units, you just have to implement the switching in your software.
Regards
Tom Sisk
http://www.siskconsult.com
On the Parallax website, it clearly says they can go up to 19200 baud.
False advertising is a bummer!
Randy
Since the transmitters are the same frequency, they interfere with each other. This means only one tx can be on / enabled at any time, so now I realize you MUST have intelligence on both sides of the link to constantly turn the transmitter on only when you are transmitting. This means you either need to add a micro-controller on the PC side, or hack a circuit together that takes the RTS line or some other similar line from the PC's COM port and buffers it and ties it to the TX enable pin on the transmitter. Then your PC's code needs to control this pin during communications. They could have made this so much easier by simply making them different frequencies. What a shame.
I think I'll give up and buy Sparkfun's wireless modem:
http://www.sparkfun.com/commerce/product_info.php?products_id=155
-Randy
Now, in my ulitimate application (robot in the woods), this wouldn't be an issue, but it sure makes development a bear...
Also, except for the above mentioned interference, I had no problems at 9600 bd.
John R.
8 + 8 = 10
··············· ·http://www.neteon.net/prod.aspx?clvl=4&c1=1&c2=83&c3=256&p=416
·········· and a cheap bluetooth dongle for the computer end . the interface is uart ?·could this work for short range reprograming ?
······· it says transparent serial cable replacement
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
...and I believe they do have a maximum baudrate of 4800. I had a project in which I had to have the baudrate at 2400 to keep it talking...fairly dismal.
There are other RF Devices that you can use such as XBee / XBee Pro
http://www.maxstream.net/products/xbee/xbee-oem-rf-module-zigbee.php
Nordic:
http://www.sparkfun.com/commerce/product_info.php?products_id=151
or use wifi wireless
