RF Array Help???
So I have been playing around with RF Transmitter & Receiver (#27980 & 27981) for the past few weeks, and hit a rather odd snag...
Transmitter Code:
Receiver Code:
Now here is what has me scratching my head. When I run the code, the debug window on the transmitter shows that the array is filled with the correct values - no problem here.
However, in the debug window for the receiver code, I will get:
The junk(2) value is not supposed to be 0. If I change the code to only SEROUT junk(0) and junk(1), then I will get:
Anyone have any ideas as to why the last transmitted value is junk?
Thanks in advance!!
Transmitter Code:
junk VAR Word(4)
index VAR Nib
junk(0) = 2048
junk(1) = 2054
junk(2) = 2050
junk(3) = 2501
FOR index=0 TO 3
DEBUG ? junk(index)
NEXT
PULSOUT 7, 1200
SEROUT 7, 16468, [noparse][[/noparse]"!!", junk.HIGHBYTE(0), junk.LOWBYTE(0), junk.HIGHBYTE(1), junk.LOWBYTE(1),
junk.HIGHBYTE(2), junk.LOWBYTE(2)]
Receiver Code:
junk VAR Word(4)
Main:
SERIN 15, 16468, [noparse][[/noparse]WAIT("!!"), junk.HIGHBYTE(0), junk.LOWBYTE(0), junk.HIGHBYTE(1), junk.LOWBYTE(1),
DEBUG ? junk(0)
DEBUG ? junk(1)
DEBUG ? junk(2)
GOTO Main
junk(0) = 2048 junk(1) = 2055 junk(2) = 0 <-------- THIS IS MY PROBLEM
junk(0) = 2048 junk(1) = 6 <------------ AGAIN, A PROBLEM
Thanks in advance!!
1) There is some delay in the transmitter or receiver that affects the reliability of the last few bits received.
2) The two Stamps have a timing difference so that after several characters, they lose synchronization
Some things to try:
1) Transmit an extra character. $FF has the advantage of leaving the transmitter off after the serial start pulse
2) Reduce the Baud from 9600 to 4800 and see what happens.
I know the transmitter/receiver is supposed to be good to 19.2KB, but the system isn't working.
- Stephen
