Pbasic to VBA Help
I am trying to hook my BS2 upto Excel for reasons of using VBA and having extra computer power. There is a spread sheet Parallax uses that allows a simple 1 or 0 function to change in Excel, but I want to be able to use PBasic and VBA together so I can have more commands and more variables.
My current robot is running out of memory all the time and I am always running out of variable and constant space. If I can get VBA to work with PBasic then I could run a wireless connection and solve a lot of problems.
Does anyone know how to do this?
DEBUG "CELL,SET,A5,1000",CR ' set cell A5 to 1000
DEBUG "CELL,GET,B8",CR ' read cell B8
DEBUGIN DEC CellData
Combine it with some XBee wireless transceivers and it could work great for what you need.
It should be available in a couple weeks if it sounds like what you need, but if you Email me I could send you what I have so far.
martin@selmaware.com
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
-MH
Martin Hebel
