Water sensing
Hey all. I have an interesting concept for you to chew on.
One of my robots I use to sense a level of water. When the water hits a certain level the robot shuts the water off, the container filled is about the size of a plastic gallon milk jug.
There are a zillion ways to do this, however I am interested in what others think would work.
You can·glue a strip of foil on the container, and put a contact in the water. The strip of metal/container/water will act as a capacitor and the value will vary with how full. Use RCTIME to see how full.
If the container is in a non humid enviorment, you could also try an ultrasonic sensor.
Or as mentioned above, a strain gauge. Parallax sells one, and you should be able to get an idea of how full the container is.
If it's just for fun, you can use a piece of conductive foam to make a pressure sensor. The kind that IC's are shipped with. If you make a sandwich with a layer of PC board, a chunk of foam and another layer of PCB board, you will see that the resistance varies when compressed. Use as part of a voltage divider. The drawback is that the foam compresses over time.
Just some silly ideas...
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Tracy Allen
www.emesystems.com
Currently its sensors are·based on springs and microswitches, but weight would work and possible sonar if the water was allowed to sit a few seconds.
One of the parallax guys told me about a fish tank they have with IR sensors set up so that when the fish swims past an IR the tank wanders around the office.
John R.
8 + 8 = 10
Tim
This robot should be constructed in the form of a broom, walking on the tips of bifurcated bristles. One arm carries a small bucket as it goes to a fro from sink to jug. The other arm reaches into the jug with its finger and feels for water. No?--Continue trip with more water. Yes?--Stop filling. Leave out Mickey Mouse and the axe. However, the wizard behind all this should probably stick around, just in case...
Tracy Allen
www.emesystems.com
Jonathan
-Stephanie Lindsay
Editor, Parallax Inc.
I like the idea of the float with reed switches or a float with a microswitch.
For illustration purposes:
It will act like a switch that closes when the water level reaches the stripped ends.
