Out of Memory
Working with a loop - I wanted to print a value - I noticed that if I do the following I get no error
import stamp.core.*;
public class MEM {
· static int val ;
public static void main(){
do{
val = val +1;
System.out.println(val);
}while(true);
How ever if I do the following - I get a memory error after a count of approx 2000
public class MEM {
· static int val ;
do{
val = val +1;
System.out.println(String.valueOf(val));
}while(true);
Can I clear a buffer or something ?
I have a routine where by I want to send an int·out·via the Uart·- I can not
use the following
txUart.sendString(val);
because val is an integer so I tried the following -
txUart.sendString(String.valueOf(val));
which successfully sent the values but I get out of memory errors after about 2000
I wrote the above routine 'MEM'·to see where my problem was and it was with (String.valueOf(val));
is there a way around this?
Any help greatly appreciated.....
public class MEM {
· static int val ;
do{
val = val +1;
}while(true);
public class MEM {
· static int val ;
do{
val = val +1;
}while(true);
use the following
or is it simply rubbish code ??
used once. You can of course use StringBuffer and then reuse that.
The easiest way is to use the Format class.
char[noparse]/noparse asciiNum = new char[noparse][[/noparse]7]; //holds ascii representation: sign,5decimals,closing null
int value = 123;
Format.sprintf(asciiNum,"%d",value); //convert int to ascii
tx.sendString(asciiNum); //transmit all characters·exclusive the closing null
You should use my adapted Uart class.
Rename the current Uart.java to Uart_org.java
then copy my Uart.java from
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/core/
into folder .../lib/stamp/core
You will find the Format class here:
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/util/text/
copy Format.java into folder .../lib/stamp/util/text
Format allows you to print binary,octal,decimal,hexadecimal and unsigned values.
regards peter
Thats great - both worked - also tried StringBuffer with a
buffer.clear();
and it works fine !
You the man !
