Interfacing with 100 volt AC pulse
I need to interface with a 100 volt AC pulse signal. It maybe less...it maybe more. It is an unregulated voltage where I need to interface with it.
Could I use a clamping diode to read the signal??
James Long
James Long
What do you need to be able to do with or get from the signal? That would help with a possible answer. Take care.
Chris Savage
Parallax Tech Support
Sorry Chris....I'm not all there today.
James L
Chris Savage
I know your not the engineer type but can I use the following:
TOSHIBA PHOTOCOUPLER GaAs IRED & PHOTO-TRANSISTOR 11-3A1
I have it designed in the circuit already....
James L
My engineering days were in the 90’s through 2003…I used to design around the Z80 and 6502 and used the opto to get 60Hz into my CPU for NMI to run the software RTC and handle some other update tasks. But things haven’t changed all that much. I'm just more in hobbyist mode now. Do you have a datasheet (or a link to it) for the opto module?
Chris Savage
http://dkc3.digikey.com/PDF/T071/1969.pdf
It is a simple device....I just couldn't find an opto that was surface mount at the time I was drawing.
James L
That catalog page doesn’t seem to have the model you specified previously, but there are a number of units that could work on the page. You will need the datasheet since this catalog page doesn’t list the forward voltage for the LED, only the forward current. But with it you can calculate the resistor required based on the maximum expected input voltage. If you use one that has the base pin brought out you can use it to fine-tune the phototransistor’s response and bias which I have found useful in this type of application.
Chris Savage
I was just making a parts list...and found the part I was planning on using is a non stock item.
I changed to a different part, but basically the same. It has a forward diode voltage of 1.14 to 1.4.
http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=51&M=PS2811-1-F3-A
James L
Just about any general purpose unit should work. As long as you know the Forward Voltage and Forward Current you can use ohm’s law to calculate the necessary resistor. I was about 12 years old (seems so long ago) when I first needed to do this for a project, so I first experimented on the secondary output (12V@300mA) of a transformer I got at Radio Shack to see how this would work. That way I was working with lower voltage and the current was less. Always check the voltage on the secondary. Don’t just go by the rating if you do this. Anyway, you can then see what the output will look like to see if it is useful for your application. Take care.
Chris Savage
Wow....I bet that was long ago, was for me.
James L
You could use the transformer direct or just for experimenting with the signals before direct connection to the 100VAC. It is your choice. Of course the transformer is safer in a sense, but you still have to connect to the 100VAC at some point, so be careful! I’ve learned a lot of respect for electricity over the years…Which also explains why I work with high voltage stuff a lot less. Let us know how you make out. Take care.
Chris Savage
To keep the voltage within limits.
James
But thanks for all the help ......you have great ideas.
The LED inside the opto is a diode and should work as long as you have the proper resistor to limit the current. Again, this is where experimenting comes into play. Many optos will have the specification for reverse voltage but current is the bigger factor. I may have to revisit my notes from back then…
Chris Savage
···There are AC type optos that use two internal leds in back-to-back configuration. Or, you can use an external diode to limit the voltage in the "unwanted" swing of the AC wave.
· Cheers
Tom Sisk
http://www.siskconsult.com
Thanks for stepping in…As I said, it has been awhile…So, I did just what I did back then…A little research. I’m going to attach a couple of pics and the first quote below is an excerpt from the page these came from. Your comments are sort of covered in this too with the second diode…The second quote is from another forum regarding AC and LEDS. And finally a link to another page that deals with the topic. Hopefully this will provide enough information to approach this on a better foot. During lunch I looked at my notes and in fact I was using an opto designed for AC, though I have a schematic I didn’t list the part number (probably because it was a one-off). Anyway I hope this helps. Take care.
http://www.otherpower.com/otherpower_lighting_leds.html
Chris Savage
Post Edited (Chris Savage (Parallax)) : 1/11/2007 8:12:42 PM GMT
Thanks for the research Chip. Wow....now that is support.
James L
http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=425&M=PC3H4J00000F
It was just easier......and I'll add a resistor to limit the current.
Thanks for all the input guys.......
James L
I was re-reading part of the beginning of the thread and was thinking maybe this got over complicated depending on if I misunderstood exactly what you were looking for in the signal. You mentioned frequency of pulse so I assumed you meant the 60Hz signal, which the circuits I mentioned are perfect for detecting. If you’re just looking to see if there is 100VAC turned on at a given time, then you can do that with a small rectifier circuit to get DC only to the LED. As the circuit is now, you’re going to be measuring the frequency of the AC sine wave. I don’t know why this just clicked in my head, but I thought I better double check. Take care.
Chris Savage
I'm trying to measure the pulses out of a special alternator on an engine. The frequency will give me the RPM. It is a magneto type. So measuring the frequency is basically what I'm tyring to do.
I just didn't phrase my question right....which was an error on my part. The major problem is I believe the voltage changes with RPM.
I do appreciate all the reference material. you have been a big help.
I will try to ask the questions right from now on....to avoid confusion.
James L
Chris Savage
(mental burp)
Truly Understand the Fundamentals and the Path will be so much easier...
