Quadrature Encoder Example Problem
This may be due to the quadrature encoder I am using but here it goes...·
When using the below code from the help file (I removed the display code) when I WATCH the encValue using
debug, or even putting encValue out to a port with leds, the count always increments and decrements by 4 decimals. When I turn the encoder VERY slowly, between clicks(my encoder has 32 lock positions) it will show the first two bits momentarily, but they dissappear...
So I turn my encoder one click, and it counts 4, and if I turn it again, 8.· Then I turn it back, and it counts back to 4, turn it once more back,·then counts·0.
Is this code somehow counting too many pulses from my quadrature encoder?
The encoder I am using is a·HRPG-AD32-#13C http://www.avagotech.com/assets/downloadDocument.do?id=610
Any code suggestions on how to deal with this?
' Device Settings
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "ENCODER"
' IO Pins
EncPort VAR RA ' encoder port
TRIS_Enc VAR TRIS_A
' Constants
MaxVal CON 100
' Variables
encCheck VAR Byte
encOld VAR Byte ' previous encoder bits
encNew VAR Byte ' new encoder bits
encValue VAR Byte ' encoder value
tmpB3 VAR Byte
INTERRUPT
' Runs every 64 uS @ 4 MHz (no prescaler)
ISR_Start:
encNew = EncPort & %00000011 ' get econder bits
tmpB3 = encOld XOR encNew ' test for change
IF tmpB3 > 0 THEN ' change?
encOld = encOld << 1 ' adjust old bits
encOld = encOld XOR encNew ' test direction
IF encOld.1 = 1 THEN
IF encValue < MaxVal THEN ' if max, no change
INC encValue ' increase value
ENDIF
ELSE
IF encValue > 0 THEN ' if 0, no change
DEC encValue ' decrease value
ENDIF
ENDIF
encOld = encNew ' save last input
ENDIF
ISR_Exit:
RETURNINT
PROGRAM Start
' Subroutine Declarations
' Program Code
Start:
encNew = EncPort & %00000011 ' read encoder pos
encOld = encNew ' copy
encValue = 0 ' clear value
OPTION = $88 ' interrupt, no prescaler
Main:
GoTo Main
' Subroutine Code
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
